Facom Tools
R25_GTS
UK, Yorkshire
I went today to a local store to check the play and wobble in the Toptul sockets :D . There is even more play than in the Facom set. The 1/4 handle + socket is the godfather of the bells. :eyecrazy: :Twitch:. So please check your tools, all types, from all over the world, and tell me if this is normal or i will go crazy.
Cheers
Monte
Germany
Heyco, Gedore, Matador 1/4" have play, larger (3/8", 1/2") from Gedore + Matador not, so maybe there is generally a problem with 1/4". No problems so far with Hazet in 1/4" (+ larger sizes).
If the Toptul wobble is even more than the Facom ---> trash can
superautobacs
Vancouver, BC
@maxipouce
Hi, thanks for the picture. I have seen the bits also for sale on EBay France. The strange thing is where did my set came from? The ratchet is the new style, the handle old style, the bits seem even an older style.... weird.
Like the ones Maxipouce referred to, Wera has their Bi-torsion bits, which are shaped just like your 'problem' Facom bit. The bits are designed to be driven under power use so it's not meant for bit holders that rely solely on ring retention (like the Facom one you have), but with bit holders that are magnetized.
Regarding the play with 1/4" drive tools: 1/4" seems to be the drive size that's the hardest for manufacturers to produce under close tolerance. I firmly believe that the Japanese brand, Nepros, sets the highest standard in that area. Even they can't consistently produce 1/4" drive tools with zero play. I've found that the scalloped area, inside the female end, that accepts the ball of the male end, are not always equally machined on all four sides. There's usually one particular orientation that creates the tightest fit, while the other three orientation gives a slight amount of play. The amount of play you're experiencing is unacceptable. It's a product of a factory that doesn't employ quality control, whether it be at all manufacturing stages, or just the final inspection. If the company/factory cared about staying within tolerance ranges, those items should've been caught before final manufacturing stages.
Monte
Germany
Inspired by R25 GTS i made a short video of different sockets (Hazet, Bahco, Proxxon, ISI, Koken, Stahlwille adaptor) attached to different ratchets (Hazet, Facom, Snap-On, Tone, Bahco, + Hazet spinner handle) and a Hazet extension to check play/wobble.
(Unfortunately you cant always see the brand, i thought the results would be better.....but its my 1st video :) )
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/2nUsaCVqszA?fs=1&hl=de_DE"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/2nUsaCVqszA?fs=1&hl=de_DE" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
R25_GTS
UK, Yorkshire
Hi Monte
Thanks for the video, in conclusion which combination has the less amount of play? which is the "stiffer"? :) .
I have seen in the last few weeks some Facom auction on E-Bay. Something it's strange. People start to go crazy about the Facom items. The prices are getting higher and higher. There's a real battle for them. Many times they final price for a used tool is higher than a new one from the dealer :confused: ?? Even on the german E-Bay where everyone looks for Hazet and Stahlwille the same thing, they bid higher and higher for Facom. Do people know something i don't?
Regards,
R25
Monte
Germany
Hi Monte
i would stay with one manufacturer to make sure that everything fits good, some manufacturers design their tools different, for example extensions don´t have a "stop" built in etc. so i can recommend Hazet. The worst fitment was Bahco.
people are silly :)
superautobacs
Vancouver, BC
That "stop" you mention is important to me as well.
That positive stop feature is hard to find these days, no matter what the COO might be. My two favourite Japanese brands have them, so I'm happy with them. :D
R25_GTS
UK, Yorkshire
Hello Facom fans
Today I took a look on the Farnell UK website to check the price for a few Facom items. I forgot the fact that Farnell shows the COO for most of the products. So I checked the 440 wrenches :D of course. And it is .......... what do you think????? Italy. Not Taiwan or Czech Republic. For the SM.161A ratchet is Taiwan, like most of the ratchet wrenches. The regular ratchets are Italy except the small R.161 which is UK :headscrat.
Just look around for the Facom COO, it's really nice to know.
http://uk.farnell.com/facom/440-13/combination-spanner-13mm/dp/1640739
R25
Jononon
The Farnell COO statements are nonsense.
Wood County, WV, USA, NA
Hello Facom fans
R25
http://uk.farnell.com/bost/692271/combination-spanner-13mm/dp/4862259
BOST is French made. :rocker:
lestat
UK
I can confirm mine has the same loose fit and not only that, I tried all the handles in the shop and they were all like that. It didn't look right but I got a good deal on it and since everything else (extension, t handle etc.) were a good fit I bought it anyway.
The only thing I could say in their defense is they might have designed this more or less as a wobble. If you press into the socket it does tighten up, although it doesn't stay there like a true wobble plus would.
1/4 set
the cuplrit - 1/4 handle
good fit
good fit
R25_GTS
UK, Yorkshire
I don't know where are the BOST wrenches made, I only know that they are making the screwdrivers for Facom, they are a part of Facom and the screwdrivers are all made in France.
The 440 series are also available from USAG, the model is 285.
In Czech Rep. Stanley owns Tona, so yes , they could make them there. But the same thing can be in Italy. USAG is a part of Facom and the ratchets are made in Italy... I don't know what to believe. Maybe one days someone from "inside" will tell the truth.
R25
marcone
Romania
Can anybody tell me what are the dimensions of the R.2A box? I'm trying to find out if such a set can be stashed under the seat of my motorcycle.
Don't want to pay double the money for the same tools in a smaller box that you get with the NANO.
otis66
I have a set of SK ratchests with the Facom round head and the palm control. I think they have a 72 tooth gear.
mofo62
Perù
*Facom - Expo
:bowdown::thumbup::beer:
*The new Stainless steel range tested live!
V!
bimmer630
I bought a 1/2" drive metric ratchet and socket set on closeout a few years ago for only 100.00, It goes from 8mm all the way up to 32mm, has a u joint, a sliding t bar, palm control ratchet, and a speeder, in the red metal box.
great deal on great tools, the only thing with their ratchets is the black honeycomb shaped handle can be pulled off the ratchet very easily.
Otherwise I love the action of the Facom ratchet
Flash21
Awesome! I've been to 3 Moto GP races in the US and there are no tool companies there.
What race is that from?
