Favorite Harbor Freight tool
scott37300
Wisconsin
First, I hope this won't take a nose dive and will stay on track!
Second, I know there is already a HF pass/fail thread but
I'm wondering what is your favorite(or two or three) HF tools that you have bought. Based on value, quality, etc. Basically a HF pass list for tools you buy because you only plan on using them once in a while or because they are decent quality for the price. When I buy tools I try to buy the best quality I can afford, also considering how often I will use the tool. So most of my HF tools are ones that I will only use occasionally.
Here's one for me, the engine support. On sale right now for 60 bucks before 20% coupon. Good price and decent quality, especially for something I won't use often at all. http://www.harborfreight.com/1000-lb-capacity-engine-support-bar-96524.html. I thought about making one but after seeing ths one in store it looked decent and cost less then it would have cost me to make something of similar quality.
Another is the 800LB transmission jack, http://www.harborfreight.com/800-lb-capacity-transmission-jack-3185.html. 139 right now, think I paid 129. Worked great and should last for the few trannys I will need to swap out.
So what are your good, surprise, value tool purchases from HF?
AlchemyMetalworks
Casper WY
The composite ratchets in 1/4", 3/8" & 1/2" as well as the swivel-head ratchets in the same sizes.
The breaker bars.
The impact sockets.
The Earthquake air tools.
The hammer-drill.
The multi-tool (the Fein clone).
The 42" toolboxes.
Chrislols
The breaker bars.
The impact sockets.
The hammer-drill.
The 42" toolboxes.
Pretty much this!
As somebody who LOVES HF.
My most recent favorite tool would have to be my 3/8" Impact Wrench I got for $9.99
Not as powerful as a top brands so you don't haveto worry about over-torquing, yet powerful enough to spin upwards of 21mm sockets off, all the while being compact enough for anything 10mm and up
R-132 Fan
Central Texas, East of Austin
I have had good luck with the Harbor Freight 90 Amp Flux Core welder. I bought it to build the roof trusses over my work area. The welder is light enough to carry up a ladder and move around on pieces of 2 by 4 up in the air. It welded my 12 gauge C shaped perlin nicely with .035 flux core wire. Set right and used carefully it will do nice welds. I don't know how long it will last, but I have more then gotten my money back with all the welding I have done with mine.
oilslick
Central illinois
earth quake impact for home use is a great buy, wire wheels in a kit for 2.99 and hammers that break before they get lost or borrowed
neonnblack
Reno, NV
I have had mine since i worked there 4 1/2 years ago, still going strong. And yes they can do decent welds (at least to the eye) but i do nothing structural with mine.
I bought a30 gal compressor when i worked there also. Its been outside for years same oil. Starts no problem every time in cold and heat. Not bad for like 50 bucks.
Air pin and Staplers are decent, i use them frequently to repair furniture. Want to try a framing gun but dont want to spend the money to just try though.
Wesley B
No where
Pretty much this!
Alright, how did you get it for $9.99? :thumbup:
Chrislols
Doh! Since I'm a daily visitor :p, and know the manager on a first name basis she took 20% an already cheapened coupon I had, because it was an opened box, manual insert damaged etc. It was around like $12 with tax wasn't exactly $9.99, but the gun itself still had the air valve cap on, couldn't beat the price so I bought both sets of the 3/8" 8pc impacts in sae & metric in shallow! Don't even get me started on how awesome they are!
Edit: It has an advertised max torque of 75lbs/ft, and I'm really thinking f buying a 1/2" clicker and torquing my lugnuts to exactly 75fts just to see how well this baby really works!
It'd be awesome to see when the Mac 1/2" gun has to come out, or when I can be astonished over the ability of a compact $9 gun.
Danglerb
SoCal
24" breaker bar
Ratchets, composite and swivel, with the stubby 1/4 swivel most used.
24x36 plastic service cart.
Carl B
Clearwater, Florida USA
I'd say that some of the best buys I've found at HF are the DrillMaster Drill Bits. For general automotive and around the garage use - they are excellent quality, stay sharp longer than bits costing two to three times as much.
29 Piece 135° Degree Split Point Cobalt Drill Bit Set $59.99 *@#$*@#$*@#$*@#$*@#$ on sale}
I Have paid three times this much for "brand name" bits - and these are better.
http://www.harborfreight.com/29-piece-135-degree-split-point-cobalt-drill-bit-set-36891.html
DrillMaster 29 Piece Titanium Nitride Coated Drill Bit Set $27.99 *@#$*@#$*@#$*@#$*@#$ on Sale for $19.99 or less}
Excellent and amazingly good for the money. That would be true if they were twice the price.
http://www.harborfreight.com/29-piece-titanium-nitride-coated-drill-bit-set-5889.html
Then I usually grab a few 10 Packs of the smaller diameter bits in 1/16", 3/32", 7/64" etc. Because I seem to not hold the drill motor straight enough with these smaller bits.. and I snap them off.. Plus use them a lot for pilot holes in steel.
http://www.harborfreight.com/1-16-i...itanium-nitride-drill-bits-10-pack-93076.html
DrillMaster 13 Piece Titanium Nitride Coated Drill Bits - 1/4" hex shank $9.99
http://www.harborfreight.com/13-piece-titanium-nitride-coated-drill-bits-1800.html
3 Piece Titanium Nitride Coated High Speed Steel Step Drills
Used these for three years now - very handy indeed.
http://www.harborfreight.com/3-piece-titanium-nitride-coated-high-speed-steel-step-drills-91616.html
FWIW,
Carl B.
PaulR
Hadley MA
5 year old model, I use it all the time.
Lkdelta
40 mi.east of syracuse
Anything that is available that is 1 or 2 steps above my use :thumbup:...Ie
Impact grade sockets for use on my rachets
Professional grade electric tools for use in my house shop
The whole aisle of racheting straps
Cheap enough and can tighten them enough to play like a guitar
Davefr
OR
The plastic ratchets are not as bad as they sound. They're actually decent go to tools for light duty tasks.
The multimeter is also decent for basic tasks since the price is usually right (ie free).
Their 2.5qt heated ultrasonic cleaner is also decent.
kc-steve
Kansas City
The multimeter is also decent for basic tasks since the price is usually right (ie free). . .
I was struggling to figure out what my "favorite" HF tool is, but you reminded me of why I like that multimeter. I was a professional electronics tech and manufacturers rep for 30 years or so, using Fluke's products. But now gone from that business, I own several of those HF multimeters thinking if one went bad I would use another one. After a few years of owning those I have yet to see one go bad, or even be out of calibration for my needs. They are easily my favorite tool. :)
Steve
jjjrmx5
Cincinnati, OH
5-drawer service cart
Orange dead blow hammers in 1, 2 and 3lbs
100 piece security bit set in the red blow molded case
CRXPilot
west TX
I'll second the little Chicago flux core welder. I've built a few heavy duty laminate carts for a local print shop, a sign frame, and I loaned it to a gentleman rancher who used it for who-knows-what.
Very short duty cycle and lots of plastic parts, but use it gently and it works quite well.
greasemonkey44
memphis
lots; mostly disposables but also my box and many of my tools
fave one being the cart; use it day in day out and no hiccups
also using the step drill bits alot and the multimeters
gsport
Salem Oregon
man, i've sure got my use out of all my free flashlights.....
really, i'd have to say my 4.5" angle grinders, i've got 4 or 5 with different attachments on each one..
rlitman
Long Island
$7 pneumatic die grinder.
My all-time favorite thing from HF was the 4" magnetic tray that I got a whole bunch of for $1, but since it's not a "tool", the die grinder takes its place in this thread.
metal1313
clinton NJ
i feel this is appropiate, and its def my most valued hf purchase, the pacific hydro star 2.5hp, 1.5in gas powered water pump.
once it got going after sitting for a year with gas in it(thanks dad) it worked like a champ. it is kinda hard to restart when its hot though, you only feel pull for about the last 8inches of the cord but it starts right up
http://shopping.yahoo.com/794257248-1-12-clear-water-pump-with-25-hp-gas-engine/ they no longer make this model.
we may buy the 3'' trash pump soon as well. that supposedly pumps over 250gpM
Danglerb
SoCal
100 pc security bit set, I've got I think 3 sets stashed around, beat on them, but yet to ruin one.
