I need a larger capacity oil drain pan. I have seen some that a basically a large open pit with a gooseneck. Don’t know if that will splash much. I have one that is basically closed, has a large screw cap on the large face and when unscrewing that cap, there is a plastic screen that catches anything that falls. I like this style since it has 2 small screw caps to put the oil out. When you are done, screwing the large cap back on leaves everything clean. Is there something like this with keeps the oil interior covered with a large cap?
Thanks
Thanks
