favorite snap on coarse tooth ratchets?
benny27
So what is your favorite old snap-on ratchet? (THATS NOT the dual 80)
I have a f710 that is nice and smooth. Just got a f936 it does need greased but first impressions are not good. Very heavy back drag and loud. The bad part is it's a FOD so I cannot just open it up to clean and grease it.
Fedwrench
Valley of the sun
Of the older snap on ratchets, I prefer the 36 tooth series. I don't use grease on the internals, just oil. I find that they get smoother with heavy use.
wrenchr
They do seem to break in with use.
Snapped-off
Indiana
36's for me. I use superlube in them. I keep them in my travel box, so they don't see much use.
Jacobs976
Indiana
936 series is all good. If you want a set fairly cheap Williams USA ratchets are just slightly modified(marked williams with different handle shape and contour on head) with same internals.
KnurledNut
n/a
Some of my favorites:
TM737 - 1/4 39t roto-head w/ hard handle
TML70A - 1/4 long
FL936 - 3/8 long
FL721B - 3/8 long w/ hard handle
F732 - 3/8 long flex-head bent handle
F723 - 3/8 standard length w/ quick-release
Ricky Joe
Roanoke, Va.
I had a 1970s quick release ratchet that I liked. When it finally needed attention, the Snap-On representative replaced it with the new 80 tooth. I like it, but miss the quick release feature. I had a Craftsman half inch with that feature also, but it was stolen from me.
BigLeagueSmoes
Central IL
Well, I've only ever owned one snap on ratchet in my life, my FL749 10" long handle 3/8" drive. It's very smooth. It has a nice handle. Outside of the black plastic switch mechanism to change ratchet directions I think it's a good looking ratchet. The only major "downfall" is that the ratchet mechanism is fairly difficult to remove with the way the retainer clip is inset. But that's a very minor inconvenience and I'm not hard on it so it doesn't get very dirty. A little Superlube will last me years before it needs relubricated or cleaned. Maybe one day I can hand it down to someone. I also bought it for about $40 so not a bad price in my opinion for a quality ratchet with good teeth and little wear. Can add pictures later.
