Favorite Spark Plug Gap Tool?
Steevo
43.49600, -112.04300
What is your favorite, or most used spark plug gapping tool?
Mine is the thrid one from the left in this picture:
I've always liked the wire gauge rather than the wedge type, but did put a lot of hours on the AC one in the pic when I worked in a motorcycle shop in the 1970's.
Hpozzuoli
Rhode Island
I like the round ones. The auto zone is my favorite and very good quality. Not sure where the other came from. It's an am pro brand?
xjfish
This is the style I typically use, I believe I got mine from snap-on. I also have/had? a round style one, usually just grabbed from the local parts store.
malibu101
Walnutport PA
I usea similar type the one pictured above also.
Mainly because of the tool to bend the ground if necessary.
I personally prefer that type of "tool" versus the hole in some of the others the OP pictured as it allows you to open AND close the gap wheras the hole type only work to open the gap.
Unless I don't know how to use the other type? :dunno:
ihrescue
Olney, MD
I was taught the wire gauge was the most accurate. Here is one that has been in my tool box for over 40 years and was in my father's tool box before that.photo 2-5.jpg
joel63
Central FL
Me 2.
I was told very early on that this was the most accurate type. :thumbup:
rharman
SoCal
This, or the round one favored by Steevo. Usually grab the round one as the fold out job is in a pouch. Of course, the only plugs I gap these days are lawnmower & edger once a year.
kc-steve
Kansas City
Yeah, me too. I'm old school though. Back years ago, spark plugs had more to measure than today and consequently had peaks and valleys from arcing. The wire gauge worked great! But last time I checked my plugs, a wire gauge didn't make any difference on the tiny filament they have in plugs now, or least mine.
Steve
Ben Buck
S. W. Ohio
I,m with Steevo, The third one from the left.
I do have the one Proto type gauge, and two of the round wedge types.
imok
Georgia
I started out using regular feeler gauges.......but the third from the left is what I have used for many years now.
DieselRiver
Madison, WI
A what, gap tool? :lol_hitti. Even as a Diesel mechanic student, I keep spark plug sockets in my toolbox. I've never gapped them though, never had any issues.
NewShockerGuy
Northern Virginia / DC
Old thread but where can one find the AC one?
I have three of the round ones and they ALL read different on the same spark plug... it's such a PITA, it's like I have to "average" my results between the three.
I see nothing but junk on amazon so having an older tool is fine by me as long as it's quality.
-Nigel
cliftonbros89
Missouri
I have the AC Delco one that's been pictured several times. Also have the Ullman one that's pictured. Both seem good. I also have a wire gauge one similar to the Proto one pictured but it's labeled Craftsman. I also have a round Lang wire gauge and a round Lisle wire one as well. Usually go with whatever I grab first. Or it depends on which gap i need. They don't all do the same size.
crackit
North of Java
I used to use the wire gauges like the third one from the right in the OP's pic, but these days the sizes don't go up high enough (.060). I normally use the round gauges now.
mbshop
visalia ca
This is the only style I ever used. Technical school class in the late 60s required this style only.
wafrederick
Holton,Mi
Wedge type and gets used rarely.With these newer platinum and iridium plugs,the little tip on them breaks off real easy messing with the gap
DFB
Southern VT/Western Mass
I also have lots of different feeler gauges...wire type, flat bade but my fav is the same style you point out.
Pretty much the only one I use :D
Evilunclegrimace
Erie Pa
I have one of the round wire gauges that goes pretty high. Let me see if it is still in my timing light box.
Gmonkee
The coin type rides my keychain but the new plugs are cutting into it some making me question the accuracy.
I have a nice wire folding type that I trust sizing more but it doesn't cover all the sizes we go to. Been hunting for a more ranged model.
Meanwhile the coins ride and I toss them as they wear.
L.Cheapo
Numerous spark plug manufacturers recommend not touching the center electrode when gapping. For that reason, I do not use the ramp style. I prefer the type that bends the tang only, and check with a real feeler gauge.
uncwstudent
MS
I've used a few different gauges but I always seem to come back to the round ones that you get at Autozone. They make gapping a bit easier.
born lucky
Had this for years. Purchased from Jacobs Electronics.
I am blown away with the Buck tool
