Fiber washer on Toro model 20055 axle
trooper1954
Salmon Arm, BC, Canada
Hi all,
I need to replace the fiber washer in the photos....it was destroyed trying to get the pinion gear off the axle.
I have researched extensively on line with no success....no parts diagram of this model shows any washer at all for this model.
Can I just use a fiber washer that fits the bore of the axle....or is this a specific type of washer?
Thanks.
WillyBoy
Genesee valley area of New York state
It if were my task to do, I'd go my stash of mudflap material and cut out a matching piece with a couple of appropriately sized hole saws. For the center hole, a hole saw may not be needed. Clamping the material between two pieces of plywood and using a twist bit would get the job done.
T
trooper1954
Thanks guys,
PCustoms....replacing this washer was the reason I needed to get the pinion gear off
larry_g...no, this does not show my axle set up at all.
WillyBoy...great idea...thanks.
PCustoms
VT
Thanks guys,
So it's the same washer as in the other thread?
