Filling and purging problem
OptionalStop
Rochester NY
I'm running a closed loop system with a basic hot water tank. I read you can fill/purge with the air eliminator opened OR closed. With my air eliminator closed, I am able to purge all the air out but once I open it up for normal operation I get lots of air entering the system. Here is a picture of my setup:
O
OptionalStop
Rochester NY
Pump in the bucket is pumping into the bottom port on fill and purge?
Correct, that's a little giant submersible pump and I when I had it originally purged with the air eliminator closed I could verify no more bubbles were coming out. With it open, air is introduced into the system.
Sawlog
Illinois
Are you closing off all but one loop at a time when purging? We use a 1 hp shallow well pump and a 75 gallon horse tank at work to get all the air out. Need to push slot of water in hurry.
dfiler2
NW Minnesota
Use the house pressure to purge the system, purge one loop at a time. Your system pump is fine. If those are washer hoses just connect one of those to a hose bib or garden hose.
O
OptionalStop
Rochester NY
Thanks. I used street pressure to purge the system and now it's running great. The pump runs quiet and I can't hear any air bubbles.
