Filling large cracks temporary workspace floor
dkjwall
Hello,
I like to lurk a bit, don't post much. Great website, and awesome resource.
I've fixed up a small garage on my property so I'll have a warm work space over the winter months. This garage floor was poured in 1960. No re-bar or mesh reinforcement here... As you'll see in the following photos, it's got HUGE cracks, and I want to fill them up with something so that I don't fall into one and go missing. I know that the only way to FIX this floor would be to rip it out. Simply isn't in the budget.... Any recommendations on a cost effective product I can use to fill the cracks and holes for the time being? This is more of a temporary work space until I can afford to build new in a couple of years, but I gotta do something about these cracks.
Thanks for your help!
Derek.
Photos:
Grind down the high spots. Chip out the loose stuff. Widen the really narrow cracks. Use hydraulic cement, but only IN THE CRACK. Any extra on the side will likely flake/crack off.
They also make "self leveling" cement (a very thin cement), but the floor has to be very clean (no left over grease/oil spots). You should probably etch it and apply a "binder" first. Any cracks and the self leveling cement will just run in them. Do low ares first and let completely harden. Then apply a second application.
I am not certain how "durable" this is, because it is so thin. Dropping something heavy and it will likely chip/crack.
There are others here MUCH more knowledgeable than I, so hopefully they will chime in.
Gotcha640
Houston TX
Would the budget/type of work allow for a bunch of 3/4 inch ply or osb? Even better if you could build a 2x frame to skip around the big holes/ridges. The lumber would still be usable after you replace the slab.
SunsetsAndFriends
Chasing (grinding) the cracks, vacuuming thoroughly, and then filling with hydrolic cement would be very cheap and would work for the couple years that you're going to use this, until you rebuild.
dwysywd
SE Michigan - Romeo area
I saw this product in action. It's pretty cool. It's called mor-flexx and it's a rubberized mortar. They have it at a lot of concrete places.
Sent from my bag phone...
Slowgsr
Southern ontario
I'd open up the cracks with a grinder & diamond blade
Remove any debris - vacuum & blow out
Then fill with sikagrout - high strength, non shrinkage and can be mixed so it's pourable. Just fill up your cracks, once you clean/open.
Should be inexpensive, and if you put some elbow grease into the prep it should hold up decent if your slab pieces have stabilized
D
dkjwall
I like the idea of using a self-levelling concrete like MG-Krete, and maybe some cheap version of RaceDeck, but after thinking about it for a while I can't really justify it on this garage... I think I'll go the Hydraulic cement or Sikagrout route.... I wouldn't want to go the caulking route for most of it, since there are some pretty wide cracks, and some decent chunks missing... I feel like I'd use many, many tubes. I'll have to see what my local distributors have to offer.
I've started thinking about laying down a hard rubber matt over the concrete. Is there something available wouldn't make it impossible to roll an engine stand around? One of my local lumber yards sells these 3'x3' 1/2" rubber matts, but they are too soft to use in a garage.
Thanks for all the replies!
Derek.
