jpcjguy
Hi Everyone,
So after some delay because of other things coming up in life, I am back to getting ready for lights in the garage.
Background info: 48x30 garage with right side bay(16' wide) having 12' walls and a 4/12 pitched interior ceiling. The rest of the space has 10' wall with flat ceiling. See attached pics of the garage. Note: the whole space will be drywalled and painted white.
I did use the tool using the Lithonia 4ft. LED tube light fixture. I think it is close enough to the ones I am looking at - mainly because I want dimming capability.
For the flat ceiling area (32x30) I ended up with 18 lights to give me 84fc at 2.5 plane. This is spacing of 6x3 (as in the visual tool pic). If I add 2 more lights the pattern goes 5x4 to give up to 94fc but the pattern, to me, is much busier.
For the lift bay, I kind of guessed on a ceiling height of 13 to balance the scissor truss. 12 lights gets me 90fc.
I think this is the light I will go with https://www.ledlightingwholesaleinc.com/E5SLB35D4-850-p/e5slb35d4-850.htm?CartID=1 at $45 each.
Am I missing anything? Thoughts on my layout before I pull the trigger on the order of 30 lights!
Thanks,
Joe
Thanks,
Joe
