I upgraded my 20+ year old HF $30.00 welding helmet. I should have done this much sooner! It’s a Hobart Inventor series.
I also found a good spot for my Direct Oil globe. I have had this since high school. I worked at this station my senior year (no they were not in use, I’m not that old).
I finally finished the initial sanding and laid down a coat of primer. In the last 12 days it has rained every day with a total rain fall exceeding 8”. I was concerned about leaving the sheet metal uncovered any longer. I am not displeased with the results. There is still plenty of sanding and touch up to be done for sure. Considering it’s been more than 25 years since I have done any major bodywork, it’s not awful.
Slow progress this weekend. I applied some seam sealer to the rain gutter and started the next repair area. The drivers side step is a usual spot for rust. It’s not bad but it’s best to nip it in the bud.
I sprayed a top coat this weekend but I’m not very pleased with the results. The semi-gloss is a lot more glossy than I was expecting and it didn’t lay down very well. I will get some satin black and give it a go next weekend. I am considering buying a paint gun. These rattle cans are getting expensive.
On a completely different area I have the step patch panel trimmed and ready for installation. I will use the panel adhesive a friend has suggested and a few weld spots to complete the install. I could have finished it today if it weren’t for the father day festivities I did have the gift or my son’s presence in the shop this afternoon. That was great!
This weekend I glued down the step. I’m very pleased with the results. I moved on to more rust repair. I removed the passenger bottom door hinge pocket. That was a treat! I also knocked out the dent in the middle of the belt line running across the back of the cab. No pictures of the belt line yet but I’m pleased enough that I may not apply any bondo.
Not much to show for my efforts this weekend. I spent 4 hours yesterday morning getting a hinge pocket patch panel to fit. I was in no hurry since my adhesive didn’t arrive as planned. Today I finished a small spot on the firewall I have been pecking away at, it’s close
The last thing I did today was respray the roof. I will see how it turned out in the morning.
Last weekend I spent 4 hours making the first hinge pocket patch panel fit. I also resprayed the roof. Friday I dropped by to check on my front axle, no joy there
Yesterday after going to breakfast with a men’s group, I came home and rearranged the shop. I needed the lift cleared for a couple of oil changes. I decided to leave the frame off the lift so I could get the cab on it. That made things a lot easier. No more up and down from the floor to the tool box.
I glued the first patch panel in yesterday evening. Today I cleaned up around it and primed the area. I’m very satisfied with the end result. Now I just need to get the second one to fit.
No shop play yesterday. My son turns 30 this week and has decided he wants his first firearm. So we went shopping.
Today I closed up 16 miscellaneous holes on the lower firewall section. Most of them are rivet holes. There are probably another 60 holes remaining in the firewall and floor board.
Not much to report from this weekend. Nothing picture worthy for certain. We spent most of Saturday celebrating my son’s 30th birthday. He’s my youngest. I guess that makes me old! I did weld up some more holes. The count now stands at 44. I also removed 3 broken bolts from the cab floor. Two were gas tank bolts and one was a rear cab mounting bolt. One came out pretty easy. The other two put up a bit of a fight. My cab corner patch panels arrived last week. So next weekend is planned.
Yesterday I completed a 3 year search. I have wanted a set of “Buddy Bucket Seats” for awhile. They were not very prevalent in the market, so there aren’t many survivors left. I watched this set on Marketplace for a few weeks and bought them yesterday. The funny thing is, they were only 3 miles from my house. They are 99% complete and still have the original seat covers (what’s left of them).
Not much to show for the days work. I opened the shop at 6:30 am and spent the lion’s share of the day torquing the front and rear suspension and steering. Not fun but necessary
Shifting gears for a minute. I started the rehab of my seats. Overall they are in excellent condition for original 1968 vintage. I’m also reminded why I don’t try my hand at upholstery.
