Ah, okay, I've seen those before.IMO not having a bulky battery hanging off the handle is an advantage for wrenching. For construction stand up would probably be better. FWIW Milwaukee also has a high cap flat bottomed battery. http://www.milwaukeetool.com/Produc...-11-2402&CategoryName=SC:+M12+Cordless+System
I think that if/once other companies start losing part of their compact cordless market share to Dewalt, they might come out with similar styled batteries of their own. Probably not, though, for ergonomic and weight saving reasons.I've got one XC battery, it rules.Plan on getting one or 2 more. So far I have 90 degree drill, 3/8 chuck drill, Impact and 1/4 driver plus I bought the 12V grease gun. Miwaukees stuff works
Yep, it was the chucked drill.There's gotta be something wrong with the sample you're using then, because mine has a crazy amount of torque... that was one of the first things I noticed about it when I got it.
I recently used mine to wire a guest room we're remodeling and I shot holes through 2x4's with a 5/8 bit all day.
We're talking about the chuck drill, right, not the 1/4 hex bit driver?
That's also why I'm very eager to do my own independent testing. Just in case any of the other brands' demo tools were early models, broken down, or whatnot.
The M12 drilled holes perfectly fine, but as mentioned it was suggested that I lean in b/c others discovered that when pushed too hard, the M12 stalled.
In the end, I'm not sure if Dewalt will be king of the hill, but the 12V MAX tools will most definitely hold their own against the other brands' tools.
