Finally, my air system installed, Yahooo!
FIRE UP
Ramona. CA
Gents,
Long story short. A while ago I asked: Why can't PVC be used for air plumbing systems? Well I caught as much flack as a world war 2 bomber over Germany. So, I went with Copper. In short,:
1. 62' of 3/4" copper pipe
2. 38 solder joints, including corners, angles, adapters and unions
3. 15 screw joints including (1( gauge, hoses, adapters and valves
The system is entirely made up of 3/4" copper pipe. It runs along a wall, about 6 1/2' high. The compressor is 30 gallon, 6HP Craftsman horizontal unit. It sits at the rear of our RV garage where my little work area is. The newly built and installed system runs the full length of the RV garage and, has a "Flexilla" 50 spring loaded hose reel at the other end. It also has a drain there too.
With all those joints, both solder and screw together, the system was initiated at 3:50 today with 120 psi. As of right now, at 9:00 Mountain time, it's still holding at 120 psi. NOT ONE LEAK, YAHOOOOOOOOO!!!!
Scott
Crazyjake8493
Upstate NY
Looks great! I've been wanting to do a copper air system in my garage, but as time goes by I use less and less air tools, so I keep putting it off.
CNGsaves
KS and OK
Nice work OP. That's great beginning to Lifetime of service from that copper.
It can be modified and changed over time as needed. Enjoy !! :beer:
CJ7VFR
Central New Jersey
Nice, clean and effective!
Do you have any pictures of where you put the valves to let any accumulated condensation out?
Jim
Richard Cranium
central Washington
There has to be one in every crowd. Rickster shame on you, Wet noodle across both sets of knuckles.
Now on to the thread, Looks good. And no a single leak. Way to go.
Richie
F
FIRE UP
Ramona. CA
Jim
First of all, I want to thank all you for your nice comments. it's very appreciative.
Jim,
Below is the only picture I have of the one drain in the new system. That system, as has been stated, is over 50' long and, has a 2" drop in that 50'. At the end, where the "Flexzilla" hose reel is, is a vertical drop. At the bottom of that drop is a 90 degree, 1/4 turn ball valve, to be used as a drain for the system.
We live in Lake Havasu City AZ. Our humidity level is about 5-10% of the rest of the country. So, condensation in a system like this, although there, is not very much of a concern. If I was painting cars, I'd have done more to deal with it like an inline filter/moisture trap. But, being in such a low humidity region, just a single drain, at the very end and BOTTOM of the system, should work just fine.
Shoulda used PVC. How bad can it really be? ;)
Rickster,
I don't know if you're being serious or not about the use of PVC. I'm one of those that normally goes against the grain and, thinks WAAAAAAY outside of the box. Utilizing PVC as an air system, to me, would be perfectly fine. In fact, I did build a commercial air system for a glass company to build and setup, Vinyl framed windows in National City CA. That system was built over 30 years ago and, is still operating just fine. It does however, reside INSIDE a completely closed up building and basically never sees any form of elements. To the best of my knowledge, no one's died from any of that system exploding due to age or exposure.
But, when it came to building this system, I knew it was going to be subjected to extreme heat conditions and, reflected direct sunlight. So, based on the pretty severer atmosphere it might be subjected to, I elected to go copper.
OP, no leaks at all?
Was that the first try, or after a few goes?
Nexussian,
Well Sir, it was definitely do my amazement that, like stated, all those solder joints, all 38 of them and, all the screw together joints, it's held almost all it's initial pressure, for well over 24 hours now. At this minute, at 11:06 PM Mountain time, here in Havasu AZ, it's sitting at 117 PSI. And, initially it was filled to 119-120 at 3:50, yesterday afternoon. So, to answer your question, yes, it was my first shot! I've done plumbing on and off for years and, pretty much had some sort of leak with each and every job that had to be repaired or fixed. But, this job, for some space frequency reason, has no leaks.
I even used my dads REAL OLD, "Petrolite" torch for all the soldering. That torch setup is over 50-60 years old. It still works as good as when I was little which, was a few decades ago.
CJ7VFR
Central New Jersey
Jim,
Nice! Very clean and neat setup. I like where you put the air hose too. Makes for easier access to just about anywhere in the garage and also outside in the driveway to pump up car tires and stuff!
What brand/type of valve did you install for that? I ask because I am working on installing my own copper air supply system in my garage, and the last piece to my puzzle was the valves to put at the bottom of the runs to let the water out.
I live in New Jersey, so the humidity level here can range anywhere from 10 percent to 100 percent! You could practically make soup out of the humidity we get in New Jersey in August!
Jim
Rickster55
Syracuse, NY
Rickster,
Richie
For the record, yes I was kidding! Before I ran my airline, I did a lot of research and took a lot of advice from people here on GJ. I used black iron and am VERY happy with the way it turned out. There is a ton of knowledge here and it would be a shame not to take advantage of it. Enjoy everyone!
Nexussian
Alaska
Nexussian,
WOW!! :bowdown:
F
FIRE UP
Ramona. CA
Jim
Hey Jim,
The valves I used, for both isolating the system and, a drain, are short handled, 1/4 turn, 1/2" x1/2" pipe thread valves. I just cruised Lowes online and, I believe these are what I used:
http://www.lowes.com/pd_21530-34146-M88C+1/2___?productId=3351122&pl=1&Ntt=gas+valves
Scott
P.S. One thing that is important here is "Flow". (not that air head on the progressive advertisements) If you're going to have an isolation valve, that is, one that either shuts off part or, all of the system from your compressor, you want one that is large enough to "flow" enough air so that when using tools/paint equipment/etc. at the end of the line, those valves have enough air flow. In the Air tool section of the tools department, they also have valves for both isolation and drain. But, of the ones they had, some were quite small in diameter. They had larger diameter ones too but, it was just easier to pick them up the plumbing section.
Hope this helps some.
04chase
SO CAL
Been looking at those reels , I want 3 for my shop as I have their 120 volt ex cord reels and they kind of match my black and green scheme in my shop (black and green s.o. box and bendpak black 2 post lift that I'm powder coat g the yellow arms green.
I just don't like that they are max 150 psi working pressure. I have a 175 psi, 7.5 hp 80 gallon. Though I will probably regulate too 150. They are priced great and would match great too. I also like how they swing but a fairlead would basically allow the same.
Thumbs way up on the copper , I'm planning the same with a 1" main line and 3/4" and 1/2" drops
quick60
Virginia
Nice work!!! Very clean set up.
Congrats on retirement. Always nice to see a brother retire happy and healthy. I have less than two years left for full retirement myself.
NewLogik
Repentigny, QC, Canada
You did a really good job on this air system ! It's also really amazing that all those solder joints are holding up pressure without any leaks on the first shot, seriously that many joints and not even one leaking :O
Now, that give me some doubts about the way I want to get mine done, I still think that I should go 3/4" black pipe, however maybe copper could be as good or better, humm...
Thanks again for sharing your great work with us !
bry@n
Ocean County, NJ
I have been planning to do this and your install has finally gotten me to the point that I want to get it done within the next week.
Can you tell me why you went with copper over black iron pipe?
F
FIRE UP
Ramona. CA
Hey bry@an,
I answered your other question/thread but, I'll tell you here what you'd like to know. First off, I personally think Black pipe or, galvanized pipe are both SERIOUSLY UGLY! My RV garage (where the system is installed) and my two car garage are both my long time dreams. I've wanted a very nice, clean, well laid out garage FOREVER. And, in my retirement, I finally got one.
Well, obviously, if we knew we were going to purchase this home before it was built, I'd have had the air system installed INSIDE THE WALLS!! But, we happened upon this place in the painting stage which, meant it was already built.
So, what this all means is, I had to install my air system AFTER the garage was done. And, I wanted a very clean, nice looking, well working, dependable system. And that meant to me, (since I was just about drummed out of the membership of GJ.com for even thinking of PVC) that COPPER was the only alternative.
I will say this. I do have a tad bit of plumbing experience. I'm not a plumber, just have done a bit of soldering and misc. plumbing over the last 50 years. So, obtaining some soldering experience and watching seasoned, experienced veteran plumbers over the years, sure helped me when it came time for all 38 solder joints.
The things about COPPER are:
1. Get both the female and male joint, REALLY CLEAN. All that means is, purchase the appropriate rotational wire brushes for the correct diameter pipe you're working with. If you plan on using both 1/2" and 3/4", then buy both internal and external round wire brushes for each. I also used stap sanding tape too. That helps for when a soldering joint is done and all cleaned and wiped off, you can run that sanding strap over it and make it look clean and nice.
2. Get good solder and, paste. You need good paste for quality joints. The solder, comes in a variety of mixtures. I got what I got. It's for plumbing, that's all I know.
3. "Time" your joints. That is, if you know you're going to have curves, turns, angles, etc., and, those have to line up with other curves, angles and more, then, cut all your pieces or, at least that section of the system and, even if you have to, build it on the ground or, on a work bench and, if needed, use a helper to lift a built section into place. That way, you'll get a much nicer, cleaner looking, more thought out look, of a system.
And this especially applies to valves or anything else that SCREWS INTO A SYSTEM. You see, if something screws into a system, and there's no wall clearance to do it, YOU'RE SCREWED. but, if you plan on this kind of joint, and make it before you assemble the rest of the system, then install your screwed parts into that system, you're covered.
4. I used my dads old "Acetylene/Air soldering torch" for this job. It's a bit more cumbersome due to it's less-than-portable arrangement. But, it's a hose and torch assembly so, in most cases like this, it was actually a lot easier to use than a hand held tank assembly even though I had to use a striker to lite the torch each time, no biggie at all. I also have a hand held, self lighting torch. I just elected to use my dads. It brought back memories of him while I was using it.
5. The technique of soldering is not all that complex. In fact, it's actually quite simple. If you elect to go copper, and, you're not that schooled on copper soldering, a tad bit of advice here. Purchase just a few extra fittings, i.e. unions, 90 degree bends, etc. Yes, it will cost you a couple of bucks extra but, you can practice your technique BEFORE it really counts on some carefully cut and placed components of your system. That will be some money WELL SPENT.
6. And speaking of technique, the art of soldering copper is what's known as "capillary" action. All that means is, when the parts are cleaned, basted with flux or paste, then assembled, you apply your torch heat in a uniform fashion, an inch to two away from the joint, and rotate that torch so that you get all the way around your joint. Then, after about 5 or more seconds of heat applied, touch the tip of the solder, to the actual joint edge.
If you've heated the two components adequately, the solder will **** itself right into the joint. You'll see that happen. If you haven't heated it adequately, the solder will just sit there and remain hard. But, do not heat it too much. This will cause your solder to spit and sort of "boil off". Solder has a mid-range to be applied. Too little and it won't melt, too much and you run the risk of damaging the retention to the copper components.
This is why I really emphasize the "PRACTICE" of soldering before you attack your system. Good luck and I hope yours turns out as "leak proof" as mine did, ON THE FIRST SHOT!!:willy_nil
Scott
bry@n
Ocean County, NJ
Thanks for the advice. I already have a black iron pipe on the opposite wall for a gas line in the garage for a heater. That is one reason why I though of it. Also, because I could paint it. I like the idea of copper though and it will be easy to do. I wonder if going copper is more expensive or not over the black pipe? I'm sure it will be cleaner overall for the tools etc..
