I am finally ready to fill my radiant heat system and would like those of you with more experience to look over my system before I do so.
I tested it with air and there are no leaks. Here are the specs:
1200 sq\ft, R19 in the walls, R 30 in ceiling
Slab on Grade, 4-300' loops
Takagi Condensing HWH
SE michigan
33% Propylene Glycol
Still need to extend the condensate drain valve
I bought an isolation valve kit thinking this would help me fill the system, but realized after that it is pretty much just for flushing the hwh. My main concern right now is filling it properly with the way it is setup. I have also added a pressure gauge that is not in the pic. Can I just use the hose bib connections on the other end of the manifolds?
Another question - I have read that you cannot fill your system if the slab is under 32 degrees, but I am assuming this is only if you are using 100% h2o, correct?
SE michigan
day and it's been running since. I have a high delta t right now but hope it lowers as the slab heats up
