Finished Garage - Less Dust??
blesmess94
Long Island, NY
i'm wondering if my garage will be less dusty once finished. i have 3 coats of primer, 1 coat of exterior semi gloss paint on walls and ceiling. the cement around the floor comes up about a foot - painted this weekend and i'm installing VCT Tiles shortly. will the garage be less dusty? my black corvette gets covered in dust in about a day.
just wondering - probably wishfull thinking
bmwpower
The dust you're referring to has to do with the dusting effect of concrete, which wears away a little as you walk on it, etc. Putting tile down should help lower the dust problem.
bmwpower
You'll probably still have dust no matter what you do, but at least it will help out greatly. Pollen and outside dirt is hard to keep out.
ChucksCrib
Connectivette
3 coats of primer on the walls and ceiling :headscrat . What warranted that? My neck is sore from just thinking about all that rolling.
byrdman
NC
I've got one coat of oil-based primer and two coats of semi-gloss latex on my sheetrock ceiling. You can still see the mud through it, even where the sanding was perfect. Hard to believe, I know. I couldn't believe the second coat didn't cover it either. But it didn't.
Semi-gloss white with no popcorn texture shows EVERYTHING. I could see why you might want multiple primer coats.
ZRWON
Whidbey Island, WA
WalMart sells a drywall taping compound (White color mud) in a white plastic container with blue writing...sorry can't remember name. On label it gives amount of their product to mix with a gal of paint to ad to get a texture like finish. Apply this mix with a very long nap roller and the surface will be very forgiving of drywall mud/tape blemishes, even with semi-gloss. Think it only mixes with water base paints. Might be worth a try in your case.
Wile1Coyote
Motown USA
Do you live on a busy road? Dirt Road? How many lanes? How is the weather stripping around the garage door and how often do you leabe it open? Etc.
If it really doesn't get beeter you may want to consider one of those ion air purifiers for out there, really helps keep the dust down and you should be using a car cover too.
armoredsaintt
OHIO
i think the dust is from opening your garage door too and having a black car you will see more of it, put your car in a bubble :D
Wile1Coyote
Motown USA
Had two more thoughts today while mowing the lawn. ( I live on a main road and have the same problem by the way. One makes sure your lawn gets enough water. I noticed today that my front is dry, when I edged I was shooting up big clouds of dust. Two keep the door closed as much as possible too. I actually have a spare opened I use when I mow the lawn so I can shut the door to keep grass **** out of there.
bmwpower
I'll see if I can find a picture online, otherwise I will snap one when I get home.
Basically, it's layers of sticky plastic that you can peel off when the exposed surface if completely dirty. Just pull the top layer off and the next layer is ready to go.
bmwpower
That didn't take long...
Here's an example. The one I have isn't quite as fancy with the black border, but you get the idea...
M-Funf
Petaluma, CA
You may also want to consider installing an air filtration system. I installed a Delta air purifier:
It's got three speeds and a remote. It changes the air in the room often enough for the work I do. I don't run it all the time, but I think it could be run on low when you're not working...
:beer:
bmwpower
:beer:
Where does this thing get installed?
batmbl
MS
I share your pain. I also have a black vette. They are beautiful cars, but unfortunately, if there is any dust anywhere in the county the black will attract it. I keep mine covered until ready for a "walk". It'll also lessen the chance for inadverdant bumps/nicks on the car.
automotive stud
I think a nice flannel car cover might be the ticket if it's not moving for any length of time, and maybe a california car duster in the trunk for quick touchups.
z28toz06
Connecticut
I have ablack vette also. I keep it covered and I use a duster on it. I started using adams car wax and other related products and the finish seems harder to collect dust now. It also seems to dust easier also. The meguiars stuff seemed greasy and it was hard to get the dust off of the finish. I have a weatherproof cover and a light wolf cover for the garage. if I have to leave it outside I just put the waterproof cover on it.
