Fire protective baseboard, I think.
509frank
Milton PA
I am building a 28 x 35 and I'm going to cover the walls with osb painted with white gloss paint. I do some cutting and welding and want to protect the bottom of the wall from catching fire.
I was thinking of using aluminum diamond plate 1/16 thick to cover up the bottom of the osb maybee 6 to 8 inches high.
If I were to seal the bottom of the plate with silicone it may also keep water from reaching the osb when I wash or mop the floor.
Any opinnions???
Frank
NUTTSGT
Northern Central Ohio
I think it'd a great job, although honestly, nothing is 100%.
I put some diamond plate behind my workbench and like the effect it has.
Brian_B_
North Central, AR
You might also consider stopping the OSB a few inches from the floor (if that is feasible behind the aluminum). Just in case any liquid ever gets spilled in there.
5lima30
Mountains of Western NC
Not really baseboard but I am using corrugated metal roofing as a 4' high wainscoting over my OSB walls. I got the idea from the Texas saltbox on this forum. (I had the same idea for a fire resistant covering for welding, grinding sparks, etc.
