I was going to get a Honda generator but for the spec I wanted it was going to cost me. I picked up a Firman Generator model HO7551 Duel Fuel for $799.99 with decent spec. and I plan to power my HTP pro pulse mig with it on the 240v 50a socket on the generator. Anyone else on this forum own one of these ?
FIRMAN Power Equipment H07551 Dual Fuel 7500/9400 Watt (Hybrid Series) Extended Run Time Electric Start Generator
9400 Starting Watts / 7500 Running Watts - Gas
8450 Starting Watts / 6750Running Watts - LPG
8 Gallon Tank with a 12.5 hour run time at 50% load
Includes cord with (L14-30P to 6x 5-20R) – lots of options to plug and play.
Bonus All Weather Cover with pull tight cord – protecting your FIRMAN Gen when not in use.
Low THD (<5%), delivers crisp, clean power to protect your toys, RV’s, Appliances, medical equipment, A/V equipment and much more – because we care – your friends at FIRMAN!
Outlets: (1) 14-50R Dual Voltage 120V/240V - 50A, (1) L5-30R 120V – 30A, (1) L14-30R Dual Voltage 120V/240V, (1) 5-20R Duplex 120V – 20A GFCI
Recoil and/or Push Button Electric Start (Battery Included)
Runs on gasoline or propane, giving you flexibility for everyday living - work, storm or fun – FIRMAN gets it done.
Extended propane hose (5.5ft) for convenience when running off a larger/taller propane tank
Volt Lock Automatic Voltage Regulator (AVR)
Wheel Kit with 10” Heavy Duty Never-Flat Tires and a (Folding) U-shaped padded handle
Power Stream Alternator
Max Pro Series 439cc FIRMAN Engine with low oil shutdown and cast iron sleeve
Phoenix Fat Head Block for enhanced engine efficiency
Legendary (Life Time Warranty) Service from our HQ in Phoenix Arizona, USA
Whisper Series Muffler with USDA Forest Service Approved Spark Arrester
3-in-1 Data Minder, measures (Volts, Hertz, and Hours)
Accessories Include: Oil, Spark Plug Wrench, gen assembly tools, Funnel, Quick Reference Guide and Manual
Weight – 234Lbs - Carton Measurements – 31.7"x 22"x 23.8"
