First time using a plastic welder...
JMLangford
Upstate SC
Hey Guys, I'd like to share with you the process I took to repair the broken plastic on my 2003 (20 yr old) John Deere LT150 lawn mower....
Over the years that we've had this mower, my wife has crashed into various thing in our yard when she mowed (I rarely hit anything :lol:) till the plastic nose valance/guard has shattered in several pieces.
J
JMLangford
Upstate SC
So, while I was doing some maintance and a tune-up, I decided to finally tackle fixing the plastic....I started with purchasing a 50 watt plastic welder w/100 assorted staples in 4 different shapes.
I also ordered 1400 additional staples....
First piece....this plastic welder is super easy to use!
On this next piece, I super glued it on before welding since this spot is one of the mounting points
J
JMLangford
Upstate SC
In no time at all I had it all put back in one piece....
....Except maybe for one little missing piece :dunno:
The staples hold the plastic together pretty snugly but with the vibration and flexing this piece will endure, I plan to reinforce it with fiberglass cloth and resin.
First up is a little glazing putty in the cracks on the outside face.
J
JMLangford
Upstate SC
Time to address the hole left from the missing piece
I took 4 of the straight wavy staples and melted them across the hole in a crosshatch grid, so I can layer fiberglass across the hole.
Then I started sanding the stitched areas to give the resin and fiberglass cloth something to grab hold of. (if you zoom in you'll notice I cut in some crosshatching into the sanded areas too.
And here we go.....I pre-cut most of the fiberglass patches and laid them out so I'd be ready to knock this all out in one session :lol_hittiWell.....I learned right quick that you don't mix up a lot of resin thinking you've got plenty of time to lay all your cloth :lol::lol::lol::lol: I got only the two strips you see in this pic before I had a cup of rock hard resin!!!
So.....afterwards I mixed up small batches and worked small areas till I got the whole back side covered
Now, I started to fill in the missing piece with small bits of fiberglass
J
JMLangford
Upstate SC
After it dried for a day, I drilled tiny holes in it....
....so the glazing putty would have a bit more to hold on to.
All sanded out nice and smooth.
Ready for paint....I bought a can of JD Green Farm & Implement paint which I have to admit matches pretty darn good.
But first some primer. (if you zoom in on the "D" in Deere you see I forgot to fill the cracks with glazing putty) Oh well, she'll mow :thumbup:
J
JMLangford
Upstate SC
Then three coats of JD Green!
After letting the paint dry for three days, I installed it back on the mower and I'm extremely happy with the way the paint matches the rest of the hood....
Heres a pic with better light....
And here it is out in the sunshine!
Today I got in the early Birthday present for my wife.......:rocker:
This is with the hood open (lots of clearance)
J
JMLangford
Upstate SC
Now you may have noticed the top cap of the hood is missing.....thats because I've still got some repairs to do.
This piece came off the front edge of the top (my wife snapped it off trying to open the hood - seriously :wtf: :lol: )
The other crack started about four years ago and the hole you see drilled in it was suppose to keep it from spreading but didn't work.
All stitched up....
On to this piece
Clamped in place and ready
Lookin' good....
Outside view...a few chipped places but I can live with it.
(I wonder if they make JD green glazing putty??)
larry4406
Northern Virginia
This was excellent! Thanks for the detailed tutorial! I might have to buy one of these. This one looks like yours but says its 80W not 50W like yours. Pretty cheap!
In Post 4, 4th picture, you show 2 fixtures for holding narrow sand paper. Those look really nice for getting into narrow tight spots. Where did you get those?
Smart on adding the bumper!
J
JMLangford
Upstate SC
Thanks Larry
Yeah, the welder you posted looks like a more stylized version of mine but as far as wattage goes 50W was plenty good enough to get the job done.
I got mine on Amazon also for the same price....good deal for the money.
The sanding sticks are sold several places including Amazon - I got mine at Hobby Lobby for $30 but Amazon has them for $26.....They are called "Sanding Detailer Tools"
I love 'em
Citation
Indy
That looks really nice. I did my first real plastic weld job earlier this summer. It was a plastic fender liner that got torn up. I would have just bought a used one (only $90) but I needed things fixed for a weekend trip and didn't have time to wait. I used the plastic rods you mix in while heating the area with my hot air soldering tool. It wasn't a pretty fix as the green rod contrasts with the black plastic but it has held up!.
sqznby
Coastal NC
Nice work, it came out looking brandy new.
I like that detail belt kit. Do you happen to know the length of belts they use? I can't seem to find the info on either site.
Meursault74
Southern California
Thanks for posting the process. Nicely done. I can see how that technique would be useful.
I know this isn't an original part, (as the original JD looks to be about $100)
Did you consider using an aftermarket one like this for about $19?
I've done: why buy a new one for X when I can get some tools and supplies and fix it for 3X and then have the tools for later. :)
Old tool guy
Nice job, but i don’t understand how it works. I thought staples were like for holding sheets of paper together, where you poke them through and bend the ends over. Apparently not for plastic.
larry4406
Northern Virginia
My understanding is the “staples” are a serpentine stitch across the crack vs thru. Then after stitching the crack is fused closed. Back side repair.
J
JMLangford
Upstate SC
Thanks
The sanding belts measure 1/4" wide by just a tad (1/2-3/4) over 12"
J
JMLangford
Upstate SC
Thanks
Yep - I considered aftermarket but I grew up in the time before the throw-away world. (I'm 70 yrs old)
Back then folks would try to repair items before opting to just buy a replacement.
Now I don't try to repair EVERYTHING, but I knew I could reasonably fix this piece...:thumbup:
Yes the OEM bumper goes for $103.04 and a replacement upper OEM hood (with decals) goes for $177.29 (aftermarket ones are $129.97 with NO decals)
These are Amazon prices, if you went to a John Deere dealership they would surely be more expensive
Also.....I'm retired and enjoyed some time to play in my shop!! :beer:
mike93lx
Richmond, VA
Cool, but that's not a plastic welder.
Plastic welder has a soldering iron type machine and you feed plastic into it.
Interesting distinction. So is tig without using filler not welding? Feels like that, plus this process can both be called welding even if there is another way to do it
kerrynzl
Tauranga, New Zealand
Thanks
I get where you are coming from.
I live in the land of UV [12 minute sunburn] and it wrecks havoc on plastic parts.
I practice plastic welding on $1-00 buckets that my wife uses for plants [This is to "hone my welding skills"]
She is always wanting holes drilled in them so I pierce them with a soldering iron.
You can weld plastics with a soldering iron as well.
I am pretty good at welding PVC fabrics together with a hot air gun and roller and also HF welding fabrics
[I highly recommend a Hot Air gun for plastic welding, it is like TIG welding ]
Hahaha! good point
You can plastic weld with a cigarette lighter if you really want to [and you're not fussy] 👍
I have had good success with a soldering iron and also a Hot knife [laid flat on it's side to spread]
It is only a "means to an end" and a skill
Jason280
You have motivated me, sir. I have a sit on top kayak that needs to be "welded" on the bottom, but I can only get to one side of the kayak. I have one of those plastic welder kits, but have yet to actually try it.
J
JMLangford
Upstate SC
Go for it Jason.....It's super easy to use and I actually had fun with it :thumbup:
CJM8515
i have the astro one of those, well worth the coin. also have the harbor freight soldering iron type welder that has worked well for years too.
P0234
NoVA
Results look great! I tried a plastic welding kit about a decade or more ago and didn't get the results I wanted on sportbike plastics. ABS pipe cement on the other hand worked really well. It's basically ABS and acetone IIRC and fuses with the plastic. If the JD plastic is ABS, you should use that for filler and maybe as a backer for the repairs on any new breaks.
Citation
Indy
I think those plastic parts are Xenoy, a tough resin from what used to be GE plastics. I think it was a PC blend but not ABS.
