I had a very busy fall and did not make much progress. The pressure to finish the building was relieved somewhat by getting it "dried in" with the roof and door.
Here is my overdue progress report:
I fastened the roof panels to the triple 2x12 beams with
FastenMaster 6-inch structural screws. These went through the tops of the rafters and into each of the triple 2x12 beams. I installed one screw through every rafter at each beam location. This gives the roof a lot more uplift strength than the original plan called for and hardly required any more cost or effort. I believe the traditional way of this connection is to use Simpson connectors, but doing it this way would not have allowed me to have the finished ceiling and would have resulted in exposed connectors which would have been ugly.
I then filled the rafter bays with rockwool insulation. This stuff was easy to work with and provided a tight friction-fit in the stud bays. It was easy to justify the higher cost compared to fiberglass due to the ease of *proper* installation IMO. The rockwool got a slight shower on it and highlighted the fact that it does not absorb water and get ruined (compacted) like fiberglass does. The photo below shows some raindrops that kind of sat on top without absorbing into the rest of the insulation.
I then installed the roof sheathing. I again used zip panels. I taped the ceiling seams with zip tape.
Next step was to install the door. This was my first time doing this job so I read up quite a bit on how to do it properly so that the door is strong and seals out air, water, and bugs and does not rot out the door or frame.
The first step was to flash the door opening with zip tape. I also used zip liquid flash in the corners as per the manufacturer's instructions. Since my slab was not level, I used a PVC board and shims to level out the bottom of the door opening. I then used more liquid flash to seal this at the slab.
Next, I installed a sill pan. I think this step is frequently omitted by many amateur builders and even many so-called pros. I actually called several pros about installing my door for me and every one of them stated they never install sill pans. This slap-happy approach by the pros pushed me to do the job myself and it was easy and inexpensive. I purchased a
Jamsill plastic sill pan and OSI quad max to do the job. I then installed plywood shims on one side and used composite shims on the other to shim the door. There is a real art to this process that I read up on at Gary Katz's website and youtube (links below). My installation turned out great and my door closes very tightly with zero visible light inside.
I chose an inexpensive
fiberglass door with no panels or windows in it for a modern look to match the building. Instead of panels, the door has a "shadow line" routed into the panel to give it some visual interest. I think this will look great once painted (it is currently in white primer). I wanted to hang the door first and paint it later for the sake of getting the building dried in so that I could start storing stuff inside. The brickmold that came with the door is too detailed for the modern style of the door so i will be removing this and replacing with a simpler PVC brickmold.
Finally, I installed a good quality lock and handleset by Schlage. The home stores only sell light duty locks, so I ordered a nicer quality "grade 2" deadbolt online. I also ordered a nicer quality handle online.
Here are some videos that I used to help me through this door installation process:
Zip system - entry door flashing
Zip system - T-joint flashing
Sill Pan installation with OSI Quad Max
Exterior Door installation by Lowes
How to shim a pre-hung door the right way by Gary Katz
How to shim a pre-hung door by Gary Katz - text link
