First welding helmet purchase advice.
mlyonsdc
USA
I bought a cheap HF helmet. I then bought the less than super cheap HF helmet. I then bought the Optrel and Holy **** its like someone turned on the lights!!! I can finally seen what I have been doing wrong. I can actually see the stuff everyone talks about with tig welding. That helmet is an absolute game changer and worth every penny!!!
mogandave
Bangkok
Yeah, it's like buying boots and mattresses.
danski0224
Near Naperville, IL
Interesting
How does it trigger with a piece of steel in front of the lens
It probably has an electromagnetic field sensor of some sort.
A Miller electronic hood has a setting for this. Works good when fluorescent lights false trigger the optical sensors.
It may be built in now, automatic.
f121
UK
Exactly what happened when I bought my speedglas. I lent it to a mate who plays board games, who named it 'the mask of +10 welding'
corn chip
theres obviously something built in because it triggers perfectly without fail even though the sensors are fully covered
Retroman
Mojave Desert
I guess you stayed under your price point. But being able to see what I'm welding really helped me.
I had a $90.00 Hobart helmet and hated it ended up buying a high quality helmet.
GaryM909
Calgary, Alberta, Canada
For starting out I would buy a cheap fixed lense from a local welding supply store. If you learn to weld using one of those then you can pretty much weld with any kind of helmet. Also, if you pursue a career as a welder a lot of shops are requiring the employees to use Adflo welding helmets which aren't cheap.
tester19
chigago
Had a Jackson for about 15 years and the LCD failed. I now use a nice YESWELDER helmet. They make just about anything for welding and if you have not tried a true color lens you don't know what your missing!
YESWELDER Helmet
I got the more expensive one at $80 but it has a large viewing area (4" X 3.7") with 4 sensors and the controls are mounted on the outside of the helmet which is a WAY better design than my old Jackson. Note it's a true color model with top notch optics rated at 1/1/1/1. Pretty much the best.
corn chip
if you cant pony up for a new one of good qaulity then check ebay used stuff. recently i sold a miller elite in great shape for $150 which is half price of new. another thing is ,all the better qaulity helmets have around 3yr warranty. HF ,amazon and the other off brands likely have near zero warranty at all. ill take a used miller every day over a new hf/amazon/alibaba helmet
superspec
WM louisiana
lol how funny. the high end helmets such as speed glas have full uv/ir protection at all times, in every shade, even if the batteries are completely dead. do you even know how auto dark helmets work ?
I don’t and I have a Miller so enlighten me please!👍🏻
sqznby
Coastal NC
I agree with this 110%.
Things are made too easy for the youngsters these days. Buy a fixed Jackson and flicker down like the rest of us had to do. Learn the hard way and you'll appreciate it that much more.
G-ManBart
I got this one: https://www.amazon.ca/dp/B00BWAEYV8/?tag=atomicindus04-20 . The company seems to have been making welding stuff for a long time. Waiting for it to come in the mail.
I didn't see this thread until today, but as I was reading I was going to suggest an Antra shield. I have a number of shields, but started out with an Antra AH7 that's similar to what you bought. It's light, comfortable and seems to work pretty well. It's my main TIG shield, but I am eventually going to buy an Optrel Crystal 2.0 (expensive).
For just starting out you'll be fine and after a while you'll probably have a better idea of what you really want in a shield and this will be a good backup.
corn chip
why not buy a old ************* boat anchor transformer machine while he's at it. theres a reason why stone age tech is all but extinct. theres far better ,faster, safer, more productive methods now days.
sqznby
Coastal NC
This stone age tech is still being used today in many factories and in the field.
Experience makes you better, faster, safer and more productive. Not the hat you wear.
And I would be happy and proud to use any transformer style machine.
corn chip
noding your head 300 times a day does nothing but kill your neck 20ys down the road. Hopefully the op is smart enough to realize that
GaryM909
I would do some research before spending too much. Like I mentioned earlier that a lot of shops are requiring Adflos plus if you are also doing some field work you might have to use a combo hard hat- welding helmet. Every site is different. Also you might not even like welding as a trade.
For field work I have been using $20 helmets with 2 x 4 lenses for years. I use Arc 1 auto lenses - 9 for outside and 11 for inside. I also have solid lenses just in case. Plus I use cheaters.
I have a Miller Elite which I never use. It's faster to flip the lense to grind then using the grind mode.
corn chip
adflos are badass but the good ones are $2000+ and most people dont care enough about their health that much. thats what i use but the company bought it. at home i just use a respirator. if i had my own business i would buy a adflo no question
sqznby
Coastal NC
Hey, if you want to nod your head 300 times a day, have at it. Like I said, you will learn from experience.
I have worked in one shop that supplied an Adflo all others provided Miller or what you wanted out of the catalog from the LWS
Like Gary, I used a fixed Jackson for years and went with the Arc1 in the link for years. Now I'm dependent on cheaters regardless.
brownbagg
i got like 11 helment from the cheapy almost free to a 300 dollar viking. the one i use the most is a full screen lincoln cheapy witha gold #10. the best built one is the pipeliner but I havent modified is yet for the neck clearance, they come factory tight in that area
brownbagg
i always wonder why somebody did not invent a camera with a filter monitor inside the helmet.
no704
This is a very subjective question. But I will still say for a first hood it should be fixed shade.
Monza Harry
Windsor ON
And they will work if you have enough power and even when that is suspect, all while lasting through anything short of a thermo nuclear EM pulse, or extreme heat (think fire or extreme use with a non-op fan) or corrosion, that will also do in the high tech replacements. A bad cap will take out a high tech machine, a transformer unit no not present! Virtually forever. Harry
Jswain
Calgary, AB
I think starting with a fixed lense and then upgrading to a nice auto darkening is money better spent then starting with a ****** auto darkening that you spend 1/2 of what something decent costs only to be let down in a year or two.
In the end you'll have a nice auto darkening plus a fixed lense for maybe the dirtier work, or throw a gold lense in it and use it when you're done tacking.
If you go cheap autodarkening and upgrade you get a nice lid and chances are throw the cheap one in the trash because you're sick of it flashing you, or the ones without replaceable batteries just stop working.
Not to mention flat, cheap, industry standard replacement inner & outter replacement lenses vs expensive curved ones that you deal with forever because you don't want to replace...
corn chip
most of us dont work in a spaceship factory with alien lazer beams threatening to wipe out or inverter and adf helmet
Monza Harry
Windsor ON
most of us dont work in a spaceship factory with alien lazer beams threatening to wipe out our inverter and adf helmet
Maybe not, but a nearby lightning strike, lack of use or a bad Chinese capacitor will that is my only point. Transformer machines last, is my point and learning out of date practices has given the ability to solve problems no on else where I worked had a clue how to. Harry
corn chip
i get what your trying to say but still it makes zero sense to me. when i first learned to weld ,the last thing i needed was extra difficulty added on my plate with a fixed shade helmet that didnt allow me to see what i was doing. but ya i get it. dont be a one trick pony. learn how to use plan B incase you need it. the reality for alot of us however , never in three lifetimes will we be caught in a lighting storm and have to pull the ole pipeliner helmet from behind the seat. but its good to know its there just in case
brownbagg
I got the $300 viking, its eats battery like crazy, at least one a month, so its nice to pick up a fix shield when the battery are dead as a backup
corn chip
eats batteries every month ? i would put that thing in the trash. they should last atleast a couple years
Monza Harry
Windsor ON
I'm 3 years with mine so far, Stouty's helmet is similar but I forget which one he has. Mine is in a drawer that is cracked open while I'm at work, amount it's open depends how close and how dirty my job is. Harry
cpttuna
napoleon ohio
Starting welding school in January. Will be doing on the job training work with company that does small-medium sized structural steel projects also, along with minor pipe work in the field. 95% of the training/work I'll be doing at this company will be MIG.
I want to buy a helmet that is up to spec, won't exceed $150 CAD, and last me AT LEAST 2 years. Once I start making money, I don't mind spending on a higher end 3M or Esab helmet.
I'm also drawn to low profile and lightweight helmet. I.e. those that make me look like Metroid Prime, not the boxy ones.
I came across this one and would like feedback on my choice: https://www.amazon.ca/dp/B09T644MXV/?tag=atomicindus04-20 It's $100 CAD. Which I appreciate.
go to welding supply store and see what everyone is buying
gearhead1
NC
I had the cheapest auto darkening solar powered helmet harbor freight made until it quit. I figured I’d upgrade, so got a Miller Elite from eBay, maybe it came from cornchip LOL. The thing would eat batteries! I figured out I put a rag over it when I’m not using it to block the sensors and the batteries last much longer.
corn chip
naw i sent mine to coneticut or maine. some where up there. guy probly relisted it for $300. it still had original batteries after about 2yr so i know it wasnt the one i sold
corn chip
i kept trying to figure out why my eyes never hurt welding outside at work but often they hurt in the garage at home. narrowing it down i think the only explanaition is from the arc bouncing off my shirt sneaking in the bottom and reflecting off the walls and ceiling going in the sides. so i got a bottom and top cape thing to try. the bottom should work great. the top im thinking may still let a bit of light in at the bottom when at a bench looking down. might have to put a few snap buttons or sew something on to extend it three or four inches further down my neck area. will try it tomorrow and see what happens20221111_182324.jpg
