Fix drywall or cover it with paneling
minytrker
Brenham TX
75gmck25
Alexandria, VA
Have you been able to look at the paneling to verify how much of it is really hardwood?
Sometimes they use pressed wood for thickness and then add the thin wood finish on top. The problem is that the edges are then susceptible to absorbing moisture, and moisture is going to always be there in a garage.
gahrajmahal
Cincinnati, Ohio
Your painter is telling you a fairy tale unless you have some pretty severe water damage or crumbling of your drywall. You can always repair drywall even if it has big bumps, like when my mom pulled into the garage too far and poked the front bumper in the drywall. Just cut out the dented part and replace with new. The thing about drywall in a garage is it is usually FIRE RATED, whereas the MDF you found wouldn't be. The MDF you referenced will go on decently if your stud walls are good. I would probably go for putting another layer of drywall. https://www.lowes.com/pd/Gold-Bond-5-8-in-x-4-ft-x-8-ft-Fire-Shield-Drywall-Panel/5001613083 $13.38 a sheet instead of $35.
I have used board and baton wood panels in my laundry room. These work well if you have lots of pipes or other stuff you need to cut around. It's easier on individual boards compared to cutting multiple holes in one sheet and getting them all to come out right.
Rc_Guy
Minnesota
Why not 1/4” over the existing drywall?
Benw455
WV
Fix and paint. I have drywall in my attached house going on 40 years old. it gets painted about every 10 years.
Rc_Guy
Minnesota
1/4” is what they did on a couple jobs that I did fire sprinklers on, instead of ripping out all the sheet rock and getting a dumpster for it all they just put 1/4” on, you still had the fire rating with the sheet rock under it, obviously patched holes. You have to keep the fire rating and then tape the 1/4” drywall
Boogerman
aspen cove hill
Pure ******** unless the sheetrock has been waterlogged for long periods of time. Just cut out holes and such, patch, and then parse over the wall if needed, retexture and paint. Depending on final product you want, just patching and painting may be enough. Either learn to do it yourself, or get a better drywall guy.
NUTTSGT
Northern Central Ohio
There's also the thought of added ribbed white metal over the current drywall. One and done, no filling, sanding, priming or painting.
rsanter
visalia ca
Unless the drywall is disentegrating from water damage I would think it's fixable.
Unless you just like the look of that paneling,this is what I would look at first;
Quote for plaster a this layer of what you have.
Rip it all out and install new drywall
Skin 1/4" drywall of what you have.
Those plastic textured panels they put over drywall like in wet or food service areas
1/4" OSB
karoc
Hemphill Tx
I will be using T1-11 siding 1/2 thick and primer on rough side. But 38.00 sheet, not giving it away. Just think, you never have to go through this again unless someones mom is driving in garage 😂
CraigStu
Blacksburg, Va
I think the fire rating may override this but, as a reference point, I used similar for a wall in my basement.
The wall was constructed w/ standard 2x4 and 5/8 subflooring. I hate drywall taping and mudding so got the above. I Used quick attach construction adhesive and didn't bother w/ nails or screws. It was so quick and easy compared to drywall, mud, tape, mud, sand, and finally paint.
LopezBart
Lopez Island, WA
That 1/4" drywall is pretty handy... when we remodeled our first house in San Jose, the contractor used this to cover the damaged lathe and plaster in the living room. They even managed to cover the coved ceilings.... all of it was covered with sanded drywall compound and matched the remaining plaster in the dining room very nicely.
Rc_Guy
Minnesota
That is why I suggested it. I have seen it used and it is a whole lot cleaner and quicker than pulling the old drywall off and replacing it. Just make sure and get screws that are long enough. Obviously a screw might hit the screw’s in the original drywall but you just go an inch or two up or down and re-screw it
minytrker
Brenham TX
The drywall is outer layer and the tape on all the seams is coming off (house built in 86). I am also removing cabinets so there will be a lot of holes to fill. The ceiling is the worst and also needs to be scraped since its popcorn from the 80's. I tried sticking a door protector on the wall and it just pealed right off with the outer layer of sheetrock. Its a detached garage. The painter said it would look nice when done just wouldnt last. I guess I really should have got them to clarify what lasting was.
mike93lx
Richmond, VA
Fyi, that's shiplap, not board and batten. Board and batten are vertical panels with thin strips to cover the seams
rancherbill
Foothills County, Alberta, Canada
Still no pics.
It sounds like the wall A) never had moisture control, B) Never was primed or sealed. It sounds like it is what we call fire taped - just joint taped.
Popcorn is easy to get off. Watch youtube. Put plastic sheets on the wall, Put plastics sheets on the floor grab your water source and trowel and start. I have helped my son do his house and we can do the actual popcorn removal at about a 1000 feet in 3-4 hours. Prep time for use was very low because the house was vacant.
PoorUB
Fargo, ND
My garage was built in 1987. One year I repaired the south wall. The lower few inches was rotten from getting wet. My truck parks along that wall and snow melts and gets it wet. I replaced the lower part of the wall with durarock and RFP over that. It should outlive me. A couple summers ago I tackled the rest of the garage. Patched up a few dents and replaced another rotten spot at the floor on another wall.
Say what you want, but thirty plus years and a a couple sort of major repairs at different spots. Seems like good service to me.
As for the OP, I find it hard to believe the some patches at the floor for some rotten spots, and repairing a few dents higher up wouldn't take care if his issues.
geneg
Midwest
1/4" OSB
FRP- fiberglass reinforced panels. Think of WalMart restrooms. Complete line of trims & moldings available. Use FRP adhesive with trims or plastic drivepins. An almost waterproof surface. Bright & shiny with textured surface.
gahrajmahal
Cincinnati, Ohio
Tamato tomato, The OP’s original suggestion of beaded 4 x 8 would in my opinion work well with a thin strip covering the panel joint making it a “board and batten” type of covering.
They make the beaded panel like the OP linked to but it comes as 4” wide, made of wood, approximately 1/4” thick. I used it at my son’s house on his kitchen ceiling and a downstairs bathroom. I didn’t have access to photos of that so that is why I snapped a photo of our ship lap siding, temporarily forgetting the correct name.
Thanks for keeping me on my toes!
mike93lx
Richmond, VA
Not criticizing, just clarifying as it can impact how the OP searches for stuff. If they like the look of yours, it would come up with a search for board and batten
M.Brane
1 hr N/W of LA LA Land
My place was built in '73. I just pulled some ugly old paneling off the back wall so the electrician wouldn't have to deal with it, and found old water damage/mold stains on the drywall behind it. Gotta love it. It's all gonna get replaced now.
minytrker
Brenham TX
Sorry we had storm storm come through texas so I havent even went into the garage or opened it last couple days to get pics. The drywall itself isnt falling apart, it looks like it has a texture layer thats coming off. It was never painted but may have been premiered, its not bare drywall for sure.
SSDVC
Northeast CT
Not an expert, but I believe the drywall in your garage, if attached, is usually required to be 5/8" in order to establish a 1 hour fire rating between the garage walls/ceiling and the living space. Maybe in 1986 it was different, but that's what it is now. The drywall also acts as sound attenuation between the two. If you cover the existing with 1/4", you increase the fire rating AND the sound mitigation into the living space. Putting something like T-11 or other paneling on the walls doesn't really do any of that. Ripping out the existing drywall (not necessary) and using those materials on the walls will look great, but takes away the fire rating AND the sound mitigation into the living space.
All that said, I have just started redoing my garage. For all the walls/ceiling, I am either going to add 1/4" to two of the walls and ceiling that abut the living spaces, putting "Green Glue" between the existing drywall and the new 1/4" (for sound proofing, so I can blast the music in the garage without my wife complaining) and then paint over everything...............OR, just keep the existing drywalled walls and put something like a Slat Wall system up for shelving and storage. I may try to use the Green Glue with the Slate Wall material, to see if it gives me any additional sound mitigation.
Again, just my thoughts.
gahrajmahal
Cincinnati, Ohio
Ssdvc, I have never heard of “green glue”. I am curious about it. Do you have a link?
Speaking of popcorn ceilings coming loose. The Mrs and I happen to be at my mother in laws house and this is in her garage. All the homes have this problem from the original builder’s. I’m dreading having to do this job.
minytrker
Brenham TX
I was going to post a picture but yours is exactly what I have going on. If you look above the garage door in the picture thats what spots on my wall are doing.
gahrajmahal
Cincinnati, Ohio
Well, you are going to have to saturate it with warm water and scrape it off. After it dries then prime and paint
mike93lx
Richmond, VA
If it has asbestos in it, just slap another layer of board over it, but that's not popcorn, so I bet it doesnt
rancherbill
Well, you have a huge moisture problem in your garage.
I will not give any advice as I come from and area that has the humidity you have. You'll have to get advice from southerners on moisture control.
If you put that stuff that was suggested by the painter, you'll have a nice looking mouldy mess.
PoorUB
Fargo, ND
{ump up weed sprayer with warm water and a couple drops of Dawn dish detergent. Wet it down good, let it sit a few minutes and scrap it off with a 4 or 6 inch putty knife. You might have to wet it down a couple times.
You may be surprised how fast it will peel off!
Or this,
https://www.amazon.com/POP-EEZE-Popeeze-popcorn-attachment/dp/B077Y8TWVB/?tag=atomicindus08-20
minytrker
Brenham TX
Its never wet in there and humidity stays 20-60% (about 40% average) looking back at my home automation logs. The spikes in humidity appear when opening the garage.
rancherbill
I am really not from a humid area. I do not understand vapor barriers in the Southern US. It looks like humidity is in your wall and comes out under the paint.
HERE, from the outside of a wall there is siding, air barrier (Tyvek). Stud/insulation, vapor barrier (poly), then drywall. A primed and painted wall does not get a lot of moisture to peel the paint like your. I do not know what to say about your problem.
