Fix hair trigger on mig gun?
454ragtop
Carver, MA
:mad: The trigger on my mig gun goes on if I so much as look at it sideways! Very annoying, it's constantly starting when I don't want it to. Not a cheap welder, it's a 250 amp Lincoln with digital controls, can't remember the exact model, but can obviously get it if it matters. I think it's a Lincoln Magnum gun? Anybody ever run into this? If yes, how did you fix it?
TIA, Jim
Fcvapor05
Don't touch the trigger?
They're supposed to be sensitive so that if you spend 10 hours a day welding you don't need the fingers of The Hulk on speed.
454ragtop
Carver, MA
Nah, that's not it. I've used other migs, none were like this. If it's depressed as little as .015" it turns on.
454ragtop
Carver, MA
open up the gun and see if there's a metal tab that depresses the micro switch that you can tweak .
So I did just that. First pic shows welder in question. Next is gun with 1 cover removed. Third pic shows contacts after tweaking them, a little better but still too sensitive for my liking. Arrow in fourth pic shows what seems to be some sort of stop for the contacts. Tried thinning it a little, didn't seem to help. So I cut the stop out with a wizzer wheel. Much better, can actually move the trigger a little to turn it on. Would have preferred a little more trigger travel, but this will do.
