75gmck25
When the electrician installed a new 200 amp panel he ran a large (1 gauge?) solid copper ground from the panel to the point inside the house where the water line enters the basement. There is also a new ground wire that runs outside to a several ground stakes.
While doing some demolition I accidentally cut the ground wire inside the house bout two feet before it is grounded on the copper water pipe entrance point. What is the best method to fix the break? I remember reading that this wire is supposed to be continuous from the panel to the ground point, but I assume there must be some approved way to splice the wire and fix my mistake.
Thanks,
Bruce
Thanks,
Bruce
