Flare Nut and Line Wrenches
DadsTools
I'll let the professional mechanics answer the second part, since they are most qualified. As for the terminology, I have always understood them to be the same thing. Something like water-pump pliers being called by several other names. Or like the protrusion on a ratchet that receives the socket being called a stud, anvil or post (there's even another I can't recall at the moment).
richfinn
Leeds, Yorkshire, England
Same thing, in England we don't really use the word "line"
as you do in the USA for this application, we would say brake/fuel/hydraulic pipe spanner!!!
I think the USA English wins on this one
But your completely wrong about "biscuits" that is just crazy talk :)
2ndGearRubber
Pittsburgh
different terms for the same type of wrench
sizes depend on what you're working on
Yup, same thing.
Most common use is brake fittings, larger tube nuts are better suited with flare nut crows feet and a ratchet.
But snapon. 8-14mm, and 3/16, 7/16, 1/2, 9/16. Pick which fits the rotted nut the best.
bczygan
DETROIT! Arsenal of Scrappers
Yup, same thing.
Automotive use mostly for me and maybe some machine rebuilding.
Would this list miss any needed sizes?
6mm x 8mm, 10mm x 12mm, 13mm x 14mm, 15mm x 17mm, 19mm x 22mm
1/4 in. x 5/16 in, 3/8 in. x 7/16 in, 1/2 in. x 9/16 in, 5/8 in. x 11/16 in, 3/4 in. x 13/16 in.
Bill
2ndGearRubber
Pittsburgh
Close enough. Has a bunch of rarely used sizes. Missing 9mm and 11. 9 is good for rotted 3/8. 11 is a euro size mainly.
Ralf11
This is about the worst tool to try and save money on, BTW
I don't want to sound like a SnapOn ad, but they work well, don't kill the captive nut on brake lines, and fit - besides being widely available used.
Dunno re other brands
The Fall
Austin, TX
They're different terms for the same wrench. I have both SK and Snap-on sets. I would use them on old domestic cars (1940s-1970s) from the South. Some from the Gulf Coast. So, not the Rust Belt, but old and occasionally really rusty (Corpus Christi cars).
I couldn't tell the difference between my SK and Snap-on set, the latter purchased new with the student discount. I would get SKs or Snap-ons if they were the same price. But I would pass on everything else.
If it's too rusted to budge without turning the line as well -- usually when replacing wheel cylinders -- I'd just get the double-flaring kit out. It's not a big deal. Again, I would work on cars were nothing was preformed.
This question almost always gets this answer -- SK or SO -- and from my experience there's a reason for it. SK is a very good value.
Kscardsfan
The Little Apple
Same tool with two different names. I have Matco and Armstrong flare nut wrenches with a few odds and ends craftsman duplicate sizes mixed in there. Need to find a set of metric ones soon.
setfocus
rust belt
if there's enough space between the backing plate, hub and such, you can pull the wheel cylinder out a bit and spin it off the flare nut that's seized to the line. I've done that a few times, including on a '96 chevy k1500 I use to have
plinker
Northern Wi
Most common for me is 10x12 & 3/8x7/16, other used as needed. Get Snap-on.
I have also bought a few of the Snap-on open end /flare end wrenches, I find them more useful the the normal line wrench at times. The open end is double the width of a normal open end. I've found that particularly useful as it's harder to get the wrench off center to where it rounds over.
If the tube nuts are corroded enough the line just gets replaced, so snip the tube and use a socket. Raptor type pliers can work on rounded tube nuts as well.
plinker
Northern Wi
Done this as well, works about 95% of the time for me, though truck axle lines arent much to replace either (usually).
bczygan
Being in the rust belt, I usually break the line when removing it, so while having the proper tool might help sometimes with that, the real reason I want them is to install things correctly and safely.
Bill
sberry
Brethren, Michigan
I work on a lot of ****. Do brake work on cars however I rarely use a line wrench, not never but so rare they are off to the side in their own drawer and not on the carts. A common end wrench installs just fine.
Al Borland
Have several sets of SK, (Old SK Wayne era and SK Fuc'em).
They don't work as well as my Husky ChiCom ones (spreading issues), but the ChiCom ones are fatter/thicker and don't always fit where i need them to.
Welcome to the rust belt, I guess.
Frequently, the line is rusted to the inside of the nut anyways, so break or cut the line and pound a socket on.
BlakeTheCarGuy
Roanoke Virginia
Yep same thing different name only. I have lots of different brands the only ones I have had issues with are the Harbor Freight have spread.
sberry
Brethren, Michigan
There is some good consensus that the snaps are worth the juice on these. I am not all impressed with lots of the others, I have some Proto not a lot to brag on. Sears not good at all.
A career mechanic should have a full set, a guy servicing 1 or 2 diy could manage without them.
rcbk00
I have newer sets of Snap-On and Cornwell. They both fit great, but the ends of the Snap-Ons are a little less bulky. The main difference is that Snap-On sets pop up a lot more frequently on Ebay, so those are the ones I'd recommend buying. Flare nut wrenches are the one area where I do not skimp. Being able to get a rusty fitting apart can mean the difference between a small repair and an entire weekend's worth of work. I keep the Snap-Ons in the box in the garage, and the Cornwells stay in the car bag (I drive older, rusty cars and trucks). Like others have said, if you're already planning on replacing a section of hardline, cut the line you're going to replace and use a ratchet and socket on the fitting. If you're trying to avoid replacing hardlines, then good flare nut wrenches are a necessity to get things apart. In addition to good wrenches, patience, heat, and penetrating oil are your friends.
sberry
Brethren, Michigan
A torch is a must for old car work,, and if the bottles are empty it doesn't count as having one, scrap without gas. It makes up for a lot of other stuff. All the wrenches they make are not a substitute.
wafrederick
Holton,Mi
There are even the ratcheting flare nut wrenches out now,Tribus Tools makes them and not cheap to buy paying Snap On prices for them.One wrench is $80.00.USA made with a lifetime warranty
GirchyGirchy
Central Indiana
Bill
Since it sounds like you're changing them out anyway, just cut them and use a 6-pt socket or open ended wrench to remove them instead. You can use the flare wrenches to tighten the new ones but it's often not necessary IME.
wjamyers
Falls Church, VA, USA
This post convinced me to get this:
https://www.amazon.com/gp/product/B000TQ5136/?tag=atomicindus08-20
Arriving tomorrow by 9 PM... I'm in a hurry to fix my catastrophically-failed brakes.
thanks, Man!
Dave455
Sussex, England
As others have said, different names for the same thing.
The British term was always “Flare Nut” spanner, I have my grandfathers tool box dating from the 1940’s, that has one of the drawers so marked.
With regards to size, definitely include an 11mm. Probably 90% of the times I need these in metric it’s 10 or 11 mm. I’ve used the slightly bigger metric sizes very occasionally, but the biggest metric sizes I never use. Maybe if you are working on big trucks or industrial hydraulics you might.
Chaplian
bob15
Northeasten, CT
Looks like they expanded and/or modified the old Bonney/Cam Lok wrench
nimW-vrapr3yDVFvOqq4xwgI4SYZ-8aONkihRSQRn1O3zb3BkES8rZErnAOiPYTCqPqglUjIfoeJIGQiyLqU57O4v1EjGyfU0PRAuFlwpf4YPcDUUkrmhJOPnrPvPWexMQL3uYamgLCBNw
bonneyman
Desert SW
Got some of the ole Cam-Loc's. Kinda big profile so they don't always fit, but where they do fit they are sweet.
