Floor color ? Tan or silver/gray
What color to epoxy my floor.
  • Gray/silver
    Votes: 19 65.5%
  • Tan/beige
    Votes: 10 34.5%
  • Other
    Votes: 0 0.0%
  • Total voters
    29
bagged89s10
CT
This is my house color.
Should I do tan or silver/gray epoxy?
I already have a rustoleum professional silver/gray kit that I bought and never opened a few years ago which I can use.
Gray floor, beige walls, wood cabinets, red toolboxes.
Too many decisions.
benwah
Crested Butte, Colorado
You may want to check the shelf life of the kit you previously bought, it may be expired by now FYI.
Color choice it ultimately up to you, I am a fan of gray floors and white floors.
mel80
to give you a perspective.. this is what tan color will look like...
i just did my over the weekend.. and just put down the clear coat last evening...after letting the base epoxy cure for 24hrs..
https://scontent-b-lga.**.fbcdn.net/hphotos-xpa1/t1.0-9/10516587_10152317095394164_1710134046330654725_n.jpg
bagged89s10
CT
Yes true on that it might be bad. Thats another reason I'm toying with different color options.
bagged89s10
CT
Good job on the floor!
mel80
i hope it last.. i spent.. half a day preping the darn concrete..
bagged89s10
CT
So I got 2 rustoleum tan solvent based kits so I can do 2 coats. Just debating wether I will need to clear over it or not.
mel80
suggest you to spend the extra $$ on the clear coat.. i did it .. and i think its well worth the money... suggest you do 2 coat of epoxy... i had to do 2 .. as some area of the concrete was more porous and the color turn out lighter on the 1st coat.. 2nd coat helped it
bagged89s10
CT
I'm definitely doing 2 coats. The garage is 60 years old and I had to cut and repour a 10" section by the garage door because it was cracked. Did that 5 years ago and it's been solid. I'm sure one coat would end up being uneven and blotchy.
Do I add anti skid to just the clear or both clear and base? I don't want an ice rink in there.
benwah
You can do either actually.
After last base coat is rolled out, broadcast anti-skid randomly on floor while still wet. Then, mix anti-skid into clear and roll out for a more uniform skid resistant area.
-or-
Just mix anti-skid into clear and roll.
Some industrial manufacturing floors will go like this:
Primer (broadcast silica sand randomly)
Intermediate (broadcast silica sand to refusal)
Finish coat (if epoxy, no silica sand. If polyurethane, mix 2-4 oz/per gallon of silica sand and roll on)
Those are usually in places where they wash down the floors daily or where the floor is wet constantly.
600SL
Connecticut
My old house in CT was the same color as yours. I went with grey (no flecks) strictly for utility of seeing things and cleaning up.
