floor drain
mastech08
Warsaw Ky
hello , I will be building my shop soon, before i pour the concrete i wanted to install an floor drain. I found a trench drain at homedepot it is the plastic nds. Would the plastic be strong enough or should i find a metal one? I have had much luck finding a metal one. If anyone can give me a link, and or some pic that would be great...
Thanks
trbomax
starvation lake,mi.
I used the NDS system in my shop,ran it wall to wall with a 4" line running out of each end.These go into a 55gal plastic drum (on each side),then I have 40' of 4" perf pipe laying in 2x2 drainrock trenches comming off of each one.There are 2 square floor drains also,one in my machine shop and one in the bathroom floor that are hooked to the system,and 2 utility sinks. The drums act as separaters and are the type with removeable heads for cleaning. The actual code in mi says you can only do this if the drainfield is within the footing,but since I have 3500 sq ft, that was not a problem.Anyway,the NDS stuff works great but requires a lot of time to "get right" before you pour. I built the whole drain system up on 2x10 reated that was set down first with the fall going 1/4"-4' each way.we then covered it all with good ole duck tape and poured the concrete.I'll find some pics and put them up tonight.
urgti
wayzata minnesota
chevelle64
NDS from Lowe's, works great for me. A section in front of each door.
jct
If anything heavy or with a high p.s.i. will be rolling over the drain, consider something like Polydrain made by ABT. More money, but way stronger. It's a polymer-modified cementitious material with a choice of various heavy duty grates. It has fall built in so water flows to the outlet.
flat350
illinois
I tried to order from them and the wouldnt sell it to me. The told me to go through my contractor or a whole sale
Where did you get yours?
Any plumbing wholesaler that deals in Wade,J.R. Smith or Zurn products can order similar items for you,they won't be cheap.
