Would those numbers be on it anywhere or would the seal kits be the same by chance?It’s a Walker jack. Probably either a 782, 783, or 784.
I googled Walker G924 and found this. ...Would those numbers be on it anywhere or would the seal kits be the same by chance?
Seal Kits - Lincoln (Walker)
Model #784, Series # I, Floor Jack 4 Ton (Base Casting No. G924)
Manufacturer: Lincoln (Walker)
Hydraulic Repair Seal Kit
NOTE: Casting Number on Hydraulic Unit: G-924
NOTE: Cast Iron Frame
Ram Diameter 1-15/16
Pump Diameter (High Pressure) 5/8
Pump Diameter (Low Pressure) 1-7/16
OEM Number: 5-953, 5-914
Thanks a bunch!I googled Walker G924 and found this. ...
Lincoln (Walker) Seal Kits | Model #784 | Lazzar's Floor Jack Repair Parts | Lazzar's Floor Jack & Hydraulic Cylinder Repair Center
Lazzar's Floor Jack & Hydraulic Cylinder Repair Center sells seal kits and repair parts. Looking for the Lincoln (Walker) Seal Kits 784? We have it!www.hcrcnow.com
