Floor jack identification
Jcumin
Can someone please help me identify this floor jack so I can order a seal kit for it and get it working again?
4 ft long
G924 stamped behind cylinder
G2613 stamped at base of handle
G914 stamped inside of frame
Any help is greatly appreciated.
WWheeler
Middleofnowhere USA
Would those numbers be on it anywhere or would the seal kits be the same by chance?
I googled Walker G924 and found this. ...
Seal Kits - Lincoln (Walker)
Model #784, Series # I, Floor Jack 4 Ton (Base Casting No. G924)
Manufacturer: Lincoln (Walker)
Hydraulic Repair Seal Kit
NOTE: Casting Number on Hydraulic Unit: G-924
NOTE: Cast Iron Frame
Ram Diameter 1-15/16
Pump Diameter (High Pressure) 5/8
Pump Diameter (Low Pressure) 1-7/16
OEM Number: 5-953, 5-914
