Floor Jack - Need height extension
ddurrett896
VA
Have a HF Pittsburgh car jack and always have to put on 2x to get the wheels off the ground.
Anyone have a height extension they recommend? Thanks!
thaxboyd
Utah
Do they make such a thing? I usually set a 2x4 on the top if needed. I am sure you are aware but be careful not to go to high or you can't roll it under lower cars
ItsNemo
Canada
Buy a taller jack...putting it on a 2x is risky, the jack needs to be able to roll while lifting. Putting much more than a hockey puck on the pad is going to risk being tippy.
MJK
Tucson, AZ
I was in a similar situation many moons ago and bought an AC Hydraulics DK13HLQ. Low saddle height, long reach, higher lift and much more robust than my prior HF.
Whatever you decide on, IMO this is a situation where you pay up for safety and convenience. My wakeup call was when the seals gave out on my HF. It went in the trash the same day.
ericm
Southern Oregon
I did that to change a tire on my Tundra 2wd truck. The 2x4 broke as I was lowing the jack. If it had broken a little more or a bit earlier it would have dropped the truck suddenly, possibly on me.
I'm not doing that again. I bought a new jack that lifts higher. It's low point is nearly as low at the low profile "racing jack" I had been using. It's high point is 6" higher. It's also longer and much heavier.
thaxboyd
Utah
Fall ON you while lowering? Were you under the truck :headscrat
I'm 50 and have done that MANY MANY times and have not had a problem, granted I only do it to get it up and down from jack stands and not to work under.
nh_yota
Seacoast New Hampshire
My Torin SUV jack came with a jack extender.
Ironically I rarely use that particular jack on my Tacoma because the lift cup is just a little too small to fit the lift point on the front crossmember securely. I use my regular Craftsman 3 ton monster instead and it just barely lifts high enough to get the front wheels off the ground.
ericm
Southern Oregon
I wasn't under the truck, just changing a tire. But when you're doing that you have your hands inside the fender well at times. The truck dropping some inches at the wrong time could catch you.
I have done it a bunch of times too. Now I think it's a bad idea with a vehicle that heavy.
Dustball
Hudson, WI
I've got this one, works fine.
https://www.harborfreight.com/steel...m-60762.html?_br_psugg_q=floor+jack+extension
bad_idea
Pasquotank, NC
That is an excellent idea. I just have to figure out how to convince the wife we need this jack instead of making the mortgage payment this month. :lol_hitti
Quality doesn't come cheap. :)
pbon
Use a 4x4 or 4x6 or 6x6. Or buy a higher lift jack.
driftpin
MJK
Tucson, AZ
Quality is certainly not cheap, until you start comparing to medical bills.
I bought my AC from Pelican Parts 10ish years ago, and while the price stung a little I would do it again.
There are some similar designs that are more budget friendly now. I haven't used any of them, but some of the models at ASE Deals look of nice design. Maybe they are worth checking out?
ezover
3rd rock from the sun
when lifting the truck I have sections of 2x6, 4x6, that I set a jack saddle into. then set it on the floor jack saddle. never had one split and the bottom saddle bites into the wood so no slippage.
NUTTSGT
Northern Central Ohio
I have a friend who used a flat jack pad, after removing the rubber pad, welded on a section of square tubing. He uses it on his sons race car to get it high enough on the taller stands or blocks.
Jeepster04
I've always just used oak blocks. Make sure not to point load the wood so that it may split it as someone above said.
And you do need to get under a vehicle to place/remove jack stands. Always makes me a bit nervous; on some vehicles you really have to get under there to place the stand.
And I would NOT use those jack extensions. That would put a big moment force on the jack if the jack isnt able to very freely roll, like on a rough driveway.
CraigStu
Blacksburg, Va
I would take the OE pad off the jack first to see how it is attached. Then you could decide if it is viable to have something made up to make it taller. I recently used two of my jacks to re-expand the culvert pipe under my driveway that the big trucks smashed to half height during construction. One of the pads was off in about 2 minutes but the other took a bunch longer as I needed to disassemble a lot of the end of the arms because one pin was blocked by another part which was partially blocked by another part. The simple one would be easy to weld up a taller replacement and they would be able to be interchanged in about 2 minutes. The other I wouldn't even bother.
