ddurrett896
Have a HF Pittsburgh car jack and always have to put on 2x to get the wheels off the ground.
Anyone have a height extension they recommend? Thanks!
Do they make such a thing? I usually set a 2x4 on the top if needed.
I did that to change a tire on my Tundra 2wd truck. The 2x4 broke as I was lowing the jack. If it had broken a little more or a bit earlier it would have dropped the truck suddenly, possibly on me.
Fall ON you while lowering? Were you under the truck
I'm 50 and have done that MANY MANY times and have not had a problem, granted I only do it to get it up and down from jack stands and not to work under.
I was in a similar situation many moons ago and bought an AC Hydraulics DK13HLQ. Low saddle height, long reach, higher lift and much more robust than my prior HF.
Whatever you decide on, IMO this is a situation where you pay up for safety and convenience. My wakeup call was when the seals gave out on my HF. It went in the trash the same day.
I've got this one, works fine.
https://www.harborfreight.com/steel...m-60762.html?_br_psugg_q=floor+jack+extension
Use a 4x4 or 4x6 or 6x6. Or buy a higher lift jack.
That is an excellent idea. I just have to figure out how to convince the wife we need this jack instead of making the mortgage payment this month.![]()
Quality doesn't come cheap.![]()
