Floor Jack Pad
ddurrett896
VA
I've got a Pittsburg 3 ton floor jack and looking for a pad to so sit in the cup that gives me a flat surface to jack from. Everything I've seen online and fits over the cup and compress in the middle.
Does anyone have a recommendation? Basically something like a solid hockey puck sitting inside the cup. Thanks!
CraigStu
Blacksburg, Va
We don't know the details of what you are jacking but...50 yrs of using floor jacks and maybe 10 times I needed a completely flat pad. Most times the angle of the jack point changes as the jack goes up and those small outer edge ridges help keep the jack from sliding out of position. When I did need a flat pad I used a piece of 2x4 or 1/2" plywood or osb.
Jay870
HalfTonTom
Waterford, NY
I have the one Jay has. It can be a bit of a pain to line up the slot with the pinch weld, but it does the job well once that is accomplished.
rpcraft
Waco
An affordable 3d print would be easy to fit the ticket. If you can design it and have a friend print it out of TPU that is your best solution. If you have a 3d printer then design it and print it yourself. I made one my self in design but have not bothered to print it yet because all my garbage is not nice or deserving of a pad.
mm08822
OP, why is it that a 2x4 cut to fit inside the lip of the cup won't work?
pbon
I very often put a block of wood on the jack. It adds to the reach and eliminates possible metal on metal. Have a big assortment of blocks, from 1/2 inch to 6 inches thick.
dvblanch
florida
I use rubber tire pads cut from used racing slicks . They bite down into the jack saddle and do not mar anything you are jacking under.
