Floor Jack safety - Jack Rod Stand?
John McA
Pasadena
Saw this interesting device: xmas stocking stuffer perhaps?
PoorUB
Fargo, ND
Eh. I don't like the idea. In many cases you will have to slide under the vehicle to set it in place.
nbpt100
Massachusetts
I like the idea. It should only take you 5 seconds to place it. With so many newer cars not having good locations to place a jack stand, there is a market for this. I have a floor jack that has locking pins that prevent it from collapsing in case of a piston failure. Similar idea.
Let’s see. Trusting the axle on a tool to catch the weight of a vehicle if the piston fails? Especially when we grab it where we have the most leverage to bend it. I’m out.
JRC3
Southwestern OH
I could maybe see a use, but not in lieu of a proper jackstand. Might be good as an addition to proper jackstands, though there probably wouldn't be enough adjustment to use both correctly.
Could be good for holding an engine or trans when other work is being done, but again I'm not sure there would be enough fine tune adjustment to place it and lower the jack on to it. Might be good for a trailer. Might also be good for just changing a tire.
No way I'd give 140 bucks for that cute thing though.
J
John McA
Pasadena
Well. I wouldn't fake thanks and throw it in the trash if received on xmas. I have never seen one before. Thank you SEMA??
Would be interesting to see it tested. I have a 20 ton press and dad's old leaky steel jack. Hmm. Need to make some measurements.
Here is the one review from the site:
"I just got your jack rod stand to try out. Put it in my tool box to show friends when they come over. The next day my wife got a flat on the tesla.
Have you ever looked underneath a tesla? There are 4 dedicated jack points. That’s it. Everything else is aero dynamic plastic or thin aluminum battery covers.
So. I pulled out my jack and my agm jack rod stand and went to work.
It worked perfect. Only one jacking point needed. And, those teslas are really heavy. No problem for the jack stand over night. I am very pleased. Good idea guys. Good job."
