Fluke 87 age?
Laro13
The Netherlands, Europe
Today I bought a broken Fluke 87 multimeter for 7,50 euro's( $10).
It was dead when I got it, but luckily it was an easy fix.
A lot of times the fuse is broken, but that was not the case.
When I pulled it apart, I saw that the battery-leads where loose.
After some soldering, it came to life.:rocker:
Then there was a second problem, a common problem with the older fluke's.
It had a bad display. I remembered something I read on our fine forum, about this problem.
So after cleaning the contacts, the display looked like new.
I was wondering when the Fluke 87 mark 1 was produced. I think it was somewhere in the nineties.
Thanks!
scaron
ypsilanti, michigan
man, that is a very nice score indeed! i always love a quick solder joint fix. i believe the 87 mk 1 dates from the mid nineties.
zkling
It should have a serial number sticker. Just give fluke a call, they will give you an exact DOM. Good deal on a nice meter BTW :thumbup:
royesses
Remove the display and clean the Zebra strips and the mating pads with some alcohol. There is a Fluke repair kit usually available on ebay to replace the display with new. I purchased mine in 1991 and have cleaned the Zebra strips 3 times. The zebra strip issue shows up as missing segments or very low contrast segments. After cleaning it is as good as new.
L
Laro13
Yes, that is what I already did. It was a big improvement.
Thanks.
