mrjaw14
If I got a used meter I might have the meter calibrated once just to ensure it's as good as can be, but I think the OP's just needing the resolution to capture small current draw that wouldn't register on a less sensitive meter and be sure it's not phantom voltage readings.
Technically you can do a voltage drop test, but the way the OP's thinking of measuring the circuit is probably easier for his purposes. Fluke is one of the most respected brands. Certainly can't go wrong with them. There's other good brands, I have a tripplett meter personally, but I don't need it to go that low. I'd like to get a fluke meter with a built-in scope, but those are still $$$. maybe in a few years they'll be a bit cheaper. Sounds like a Fluke 87 is the model for you
