Foam tubing?
B18c_tuner
I was wondering if anyone has been successful with finding some foam tubing for their tools? Specifically for torque wrenches. I've done a google search and it seems like companies want minimum orders of 50-100 which doesn't seem reasonable for a weekend wrench like myself. I'm looking for foam tubing that can offer protection from dirt/ grime from my torque wrench handle that is aesthetically pleasing to the eye.
jjjrmx5
Cincinnati, OH
I'm not clear.
Are you looking for something foam to store it in, something for the handle/grip or something else?
50-100 what?
Sheets? Sq.Feet? Linear Ft.? Meters?
There's closed cell and open cell and both come in sheet or tube form.
Make/model and mfgr of your torque wrench would help a lot.
And I seldom see foam protect from grime and dirt. It tends to harbor it, sadly.
B18c_tuner
I'm not clear.
50-100 what?
For a minimum order most websites/ companies want you to order 50-100 pieces.
I believe I'm looking at closed cell for my application.
This is for a Snap-on QD3R250. I took measurements of he handle and I came up with:
•1.5 in. outside diameter (actual handle)
•3.5 in. length (metal only not including the rubber at the end)
For my application I doubt it would harbor dirt. I typically keep my tools clean while wrenching. Now I can see where one may have problems if the tools arnt kept somewhat clean during or neglected after a job. I was thinking something like these:
http://www.grip-tek.com/d5.html
http://www.grip-tek.com/d11.html
http://www.grip-tek.com/d6.html
B18c_tuner
Thanks for the heads up Will. I failed to check that particular website for free sample in the proper size for my application. Just sent my request and I'll keep you guys posted on the outcome.
bob15
Northeasten, CT
Skipping all the appealing looking jargon (pleasing to the eye????), go to McMaster Carr or a plumbing supply house and get pipe insulation.
B18c_tuner
As promised, here is the final product:
