For those that ask "how deep do a build my garage?"
ArcReactorKC
Out in the county NE of KCMO
The garage at our previous house was only 25' deep. I was running a bunch of projects at the time we moved and was dying to get out of the duplex we were in.
We had moved the bulk of our stuff and I tried to put the ccsb F350 in the garage and found it wasn't possible. I was pissed at myself for not even thinking about it. I just assumed "why would anyone build a garage you can't fit a full size truck in"
Now I take measurements of every space to be sure it is what we need.
I have started suggesting 30' minimum garage depth for space to move around the vehicles.
D
dcg9381
Austin, TX
Why the metal column?
Largely because I work a full time job and was busy another 4 hours after work for a long time (1+ year) and couldn't fix every detail.
Traditionally framed garage. Span is 40'+. I was told we "could" get an LVL to span it, but transporting an LVL that long (legally) was a problem. GC wanted to drop a wood post, I did that steel post instead.
If I could do it over, that post probably isn't what I'd change, it's far enough out that it doesn't interfere with car doors, but I guess you could span that with a steel I-beam... But pretty big cost swing to bring in a crew that can do a metal beam and tie it into traditional framing. Wood framing here is cheap.
I told my spouse next house I'm putting in a round pole that's plated in brass with a few fans and stage lights.
66Caprice
Stanwood, Washington
In reality that is still concidered a long bed truck. it just has two more door's than a normal truck. But yes you are correct in that garages in today's homes are too short for most vehicle's to fit.... even at 26' that would still be too short to fit that truck as long as those cabinet's remain there. Always go BIGGER!! LOL!
D
dcg9381
Austin, TX
Short bed, long cab. Is that a dually short bed? I guess if you plan to haul a load of lead ;)
Yea, the Ram 2500/3500 with that cab configuration only comes in 6'4" bed. No long bed option, although you can have one done for about $11,000.
It was bought to tow a 5th wheel. If I had to do it over again, I'd get "regular" 4-door long bed dually (or flat bed) as there are fewer issues with cab-to-RV clearance. More recently, I've used it with a truck camper that weighs about 3200 lbs loaded and tow a 16' cargo trailer with the combo.
I never thought I'd own a truck like this, but when you need to "regularly" tow over 10k lbs, it gets the job done.
I jest about it fitting in the garage a bit, it's usually in the shop, but I had to do some musical cars today and many modern trucks won't fit in "regular" garages.
ArcReactorKC
Or pull a trailer 100% of the time.
All of our trucks are short beds, I've got a lot of hate for it but all but one of them has a trailer hooked up 100% of the time. The only thing in the bed of the trucks is the gooseneck ball. A long bed just makes for a longer, heavier rig to cost more fuel and make more difficult to maneuver in tight neighborhoods.
My father refuses to buy a short bed truck because "what if I want to haul 4x8 plywood"
The reality is he hasn't put any sheet goods in the bed of his truck in a decade.
I'm not saying that long bed trucks shouldn't exist but for the bulk of people they are unnecessary.
Jim_No_Garage
Millington NJ
My garage is 23'-6" deep. I've had people say they wish there garage was as deep, but I wish I had another 6' to work with.
I can get a Dodge Grand Caravan into the left spot and have a 30" deep shelf in front but NOTHING else.
You can only put small cars into the right spot (Toyota Yaris 4 door / Hyundai Elantra GT) and have room to get past the nose to the door into the basement.
More space on the sides would be good too - it's tight with the longer doors on modern cars. I can't imagine those 1970's doors on Caddy's even opening.
Jim
TurnipTruck
Southcentral Alaska
Like an idiot, I trusted the SketchUp crewcab truck as being drawn to scale when I drew my former garage. The next year when I did buy a longbed one ton, it didn’t fit in the 24’ deep bay with a receiver hitch in, and I had to keep the overhead door open to lift that truck.
The MGB fit great, tho! ( one of the few pics I have of that building)
larry_g
oregon
I totally agree that 24' deep is strictly for parking. It does not work if you want to work on a longer vehicle in that space. I find that 30' just works and 36' works well.
lg
no neat sig line
CombatNinja
Mine is a 25' in the current house and I would never go shallower. I don't even drive trucks but anything shorter and I would feel cramped. Those 20' x 20' garages in newer homes are useless. Of course, it seems like 90+% of homeowners keep $5.00 worth of disorganized ******** in their garages while $80,000 worth of cars sit outside so I'm not sure most folks care.
kj_mustang
Harrisonburg, VA
I built my attached garage 26' deep. Handles my 19' long F150 SuperCrew just fine with some shelving in front of it. The 9' wide doors make it a little fun going in and out.
Beelzeboss
Sydney
My house was built with a 22 by 22 attached. It's gracious plenty for cars. I even have a row of shelves, home built and 2 feet wide, opposite the doors.
Ours is 17.5' x 17.5' and we had a 1993 Volvo 240 Wagon and a 2014 Mazda 6 Wagon in there... Could only open the doors in the middle of the garage, and only 1 car at a time, but it was doable. Now that there are tools in there it's used as an oversized single.
However we are only just starting to get these insanely big utes here in Australia.
oldman_pottering
Tinonee, NSW Australia
Just checked out your link seeing as you are from Au, how is that floor finish holding up now
rockcrawler
Dallas, TX
When we built our house, I had the architect make one bay of the garage longer (25’ with a 10’ wide door) for my truck. At the time I had a 2006 Ram 2500 Mega Cab CTD with the 6’ 4” bed. Now I have a 2022 Ram 1500 Crew Cab with the 6’ 4” bed. Truck fits fine with a few feet left in the front. Kinda wish it was deeper though.
andyvh1959
Green Bay WI
I built my shop (mostly motorcycles) back in fall of 2019. Built it 24x28, and then in 2023 I came across a 1956 Dodge pickup I just couldn't pass on. Wished I had buily the shop another four feet deeper to 32 feet (I sized it in four feet segments).
rharman
SoCal
Around here, garages are disappearing. Everyone is converting to an ADU. One across the street, two right around the corner - they're multiplying like rabbits.
Sometimes they make sense. One is going to be for the neighbors son and new wife. They will have a place to live and save up for their own home. Another, we think, is being built just to get more room. Young couple with two kids coming into their teens. Boy & a girl. 2-bedroom house. The kids each need their own room. Or, could be a granny flat. Don't know.
MushCreek
Upstate South Carolina
They built two houses in our neighborhood recently. The so-called two car garages are 18' 8" wide and deep. Needless to say, they keep their cars outside for the most part. My wife's Olds 88 was 12' wide with both doors open. You do have to get in and out of the car, too. Our attached one-car is 15-1/2 X 23-1/2, and it's comfortable for our RAV4.
Old Moparz
Newburgh, NY 12550
This is 24' deep garage.
Short bed truck.
Won't fit with shelves... Should have gone 26'!
Long bed truck? Maybe 28-30'!
That's a nice truck, I'd move or lose the cabinets to keep it inside of the garage if this was my situation. I have an older Dodge Ram, a 2004 Quad Cab with the 8' bed. I might be wrong but I believe it may be the same length as your Mega Cab with the short bed. I can fit mine inside a 24' deep bay in my garage without anything against the wall.
1/4atatime
VA
As someone who's house didn't come with a garage I always drive by others houses with garages in disgust. People literally put anything else but cars in garages meanwhile I'll be happy when I get my meager 28ft wide x 25ft deep garage built. I was planning 26ft deep and 30ft wide but zoning and utility/septic lines are keeping me from going deeper and wider. I think 25ft deep with NO shelves in front of the truck bay is probably the minum you can get by with for parking todays trucks and SUVs inside.
txvwnut
Bedford, Texas
When I built my shop I was restricted to 500 square feet on the ground. I decided upon a 20' x 26' as that would allow enough room for two aircooled veedubs to be side by side if needed but foremost I would have a good amount of front and back room to work with. Somewhere I have a picture of my long bed extended cab superduty in the garage with the back foot and change sticking out of the door and front bumper is against the back wall. My attached garage the SD would fit in length wise but the door opening isn't high enough and being its two garage doors and not a large single probably not wide enough either.
liliysdad
I built a 24x30 because that's what my bank account told me I could build.
I put a 10ft door centered in one 24' side, and one 2ft from the edge on the 30' side. I can fit my CJ5 and my Crew Cab Short Bed F150 in at the same time. Its tight, and I only do it if a storm is coming...but it works.
Aileron
outside
Daughter built a flower wall for her wedding. I asked how are you getting it there. Fiance has a truck,lol, good enough for me as they will shortly fiqure it out. I get the call becuase the truck only had a 6 ft bed and my sons F150 was a 5ft. I took them my 2000 Excursion, dropped the seats and hauled it to the reception hall. I usually try and keep it covered for the summer but had to haul the wedding dress in it the day before.
mike93lx
Richmond, VA
My cars are made to be out in the elements while most of the stuff in a garage would be destroyed in short order outdoors.
We don't park cars in our garage either.
D
dcg9381
Austin, TX
I don't consider this to be an option in central Texas. I'm super retentive about avoiding door-dings and any damage to the vehicles. I won't own anything that has wheels and sits outside if I don't have room to store it under cover. Back when I didn't have a shop, I'd drive to the nearest covered car wash and park to wait out the storm.
Sooner or later, this is gonna happen around here:
liliysdad
And you know what? Insurance covers that.
I try to get my vehicles inside if hail is imminent but I don’t stress too much about it. I have a check for $4500 sitting on the refrigerator for hail damage to my pickup from a hail even that wasn’t even predicted. Life happens, it’s a piece of metal.
I’d much rather deal with hail damage in my truck that the $28,000 claim for the house from the same storm.
