Ford OBD-1 code reader, best inexpensive one?
plinker
Northern Wi
What is a good low cost code reader going to run me?
I figure I need to have one, But I'm not looking to spend more than 100$ if possible.
I Only really need one to read Ford OBD-1 codes (though I might get a GM adapter later).
I saw this on ebay but it seems kinda cheap, http://cgi.ebay.com/ebaymotors/3007-FORD-ECM-COMPUTER-CODE-READER-sp_W0QQcmdZViewItemQQhashZitem2c4b307337QQitemZ190240027447QQptZMotorsQ5fAutomotiveQ5fTools
There was also this one,which has Ford & GM adapters.http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=260390600714
I'm new to using diagonstic tools like these, so I'm not really sure who makes a decent one.
What do you guys recommend?
cravej
If your time is more valuable than mine, then ignore me, but for what it's worth, I pulled the codes on my '95 F150 by grounding the test plug and counting the CEL blinks. This link isn't working for me at the moment, but it has the instructions for doing the self test: http://www.fordfuelinjection.com/?p=13
I think you can use a voltmeter with the older ford OBD-1 ECM's
jay50
if you are wanting an inexpensive one, you might look at the OTC 4000 series... they are outdated for most current uses, but will work with any obd1 vehicle... have a lot of adaptors available to work on different manufacturers domestic and import...
here is a link to one on EBAY
http://cgi.ebay.com/ebaymotors/OTC-...017QQitemZ270389911001QQrdZ1QQsspagenameZWDVW
Also, a few Ford OBD1 vehicles had a datastream that can also be viewed with the Monitor 4000. Had a 93 Crown Vic the other day with a datastream, rare in older Fords prior to OBD2.
