LatheMaster mini lathe 8x14, cutting tools chucks lath cnc machining - $1250 (Seattle
Not sure of the quality, but sure is a lot of tooling for the price ... looks almost new.
Price is new cost, but the tooling makes it, maybe, a good deal
$995+ $189 shipping- $1184.00
http://www.lathemaster.com/ORDERPRODUCTS.htm
http://seattle.craigslist.org/see/tls/5062244445.html
Price is $1250 OR best-offer. I may accept lower offers at any time.
LatheMaster 8x14 Mini Lathe with box of tools and accessories.
Model CQ6120X320
For those who were asking, I finally updated the pictures and have gathered all the accessories. Comes with a significant amount of tools, large chucks, etc Therefore, I've upped my asking price by quite a bit. However, I am still considering the best-offers
FEATURES:
The Lathemaster 8 x 14" Mini Lathe is the highest quality lathe in it's size and price range available.
It is a solid machine (190lbs.) with induction hardened, precision ground, Dual Prismatic ways and a sturdy reinforced frame. The spindle is constructed with quality tapered bearings.
Spindle speeds up to 2000 RPM for turning small parts. Feed ratio and thread selection are a simple task of changing a few easily removed gears. This lathe will cut left hand threads and make cuts away from the chuck with the easy installation of the included feed reverse gear. It has forward and reverse motor switching and a safety Kill Switch. All the gears are metal. ( No Plastic Gears)
True Inch Pitch Leadscrews. The Dials are all metal, satin finished, and clearly engraved in inch measure.
Specifications:
Swing over Bed: 8 "
Swing over Cross Slide: 4 3/4"
Distance between centers: 14"
Carriage Travel: 12"
Spindle speeds: 6
(125, 210,
show contact info 2000 rpm)
Longitudinal Feeds: 2 (.005,.010)
Inch Threads: 12 (8 - 40TPI)
Metric Threads: 12 (.4 - 3mm)
Cross Slide Travel: 4 1/2"
Compound Travel: 2 5/16""
Tailstock Spindle Travel: 2 3/4"
Tailstock Taper MT2
Spindle Bore: 20mm (3/4")
Spindle Taper: MT3
Motor: 3/4 HP, 110V/60Hz
Machine Size: 34"x17 1/2"x17 1/2"
Machine weight: 190lbs.
