Irwin bar clamp. Has served me well for a few years albeit not used everyday. Aligning body panels can get fidgety and on this truck the radiator frame pivots sloppily
on big bushings. Front to back position referenced to the firewall comes into play.
If you knock out the roll pin on the ratcheting end of the Irwin you can then reverse the clamp to expand instead of clamping. A big win, made it easy.
on big bushings. Front to back position referenced to the firewall comes into play.If you knock out the roll pin on the ratcheting end of the Irwin you can then reverse the clamp to expand instead of clamping. A big win, made it easy.
