Found "NO RUST BAGS" for tools etc...
TEXACMAN
Mount Pleasant Texas
I was talking to a guy in Dallas at a gun show that makes different size bags that keep tools , guns etc .. from rusting. He also makes them in custom sizes, he said he had made one for a guy to put his bare metal hotrod in to keep from rusting until he decided on paint! Thought you guys might be interested !:pimpflash
www.norustbags.net
tomsmith
How does it work? Does it have the dessicated powder inside to absorb moisture?
Stuart in MN
Minneapolis
They probably use vapor phase corrosion inhibitor (vpci) technology. It's similar to the old trick of putting a piece of camphor in your toolbox. Here's another company that sells bags, as well as emitter cups and other rust prevention products: http://www.bull-frog.com/products/ They work really well.
D-fens
Search "Zerust" on Amazon.
They make a **** ton of different size plastic storage bags, as well as these 9V battery size moisture absorption capsules.
T
TEXACMAN
The bags are not coated with anything but I do not know exact composition of bags, just thought I would pass this on to you guys. The bags are yellow in color , last 5 years and are used in military and industrial application as well. I will be placing an order as soon as I can figure out what sizes I need , was going to buy a few but ran short on time after buying firearms.:thumbup:
fivespdcat
I use the zerust infused drawer liners from lowes. They seem to work well and don't cost an arm and a leg.
T
TEXACMAN
I looked at a few items from ZERUST and these bags are the same color and could be the same material. I checked on the motorcycle bag and drawer liner and they were less than the Zerust .
jethro29
central delaware
I just use the decadent packs that comes with electronic items whem they are new,also in over the counter meds also.i have 2-3 in every tool drawer.
4xdog
Santa Fe, NM
If you keep a container tightly sealed those dessicant packs can help. In a toolbox drawer with reasonable air circulation they're probably exhausted in a few days, especially if the relative humidity is on the high side.
I have an aluminum Zarges cargo box for unused photography stuff and the dessicant packs do a great job in that waterproof, rarely-opened container.
Depending on the type of dessicant they might be able to be reactivated by some time in a low-temperature oven -- the web has a lot of info here.
