USMCBay
As always I still need more practice with pinstriping but I found these items of interest for some makeovers... Another Glass Chemists Cabinet I will use the larger one to store my Paints, Brushes, etc... the bottom will be a bed of dry desiccate to control moisture (Houston Humidity). For now I am using the smaller one... Also I found another drink fountain that just needs a knockout paint job with some striping. I will set this one next to my 3' 4" Stainless Water Fountain. This one is about 2' high which will be plumbed through a filter to supply cold filtered water to my 5yr old son and 2yr old daughter who both love to hang out with me in the garage... perfect solution vs. holding them up each time to get a drink~!
I'd like to paint the Older Drink Fountain with a heavy metal flake of some sort then pinstripe it and wrap the bottom with a small diamond plate trim that extends a bit to make it a 6" stand.
The lateral filing cabinet is great for storage the first cabinet lifts and slides in the others are giant drawers that slide out and only one at a time via internal anti-tip locks. I would like to do this black with the True Fire as seen by someone else who's first attempt at it turned out great (see www.kustomkulturelounge.com). I think that would be a great solution for the Bright colored cabinet...
