Fox Valley Fab: Shop Projects
bulletpruf
San Antonio
Thanks for checking things out Duker.
Hey Mark, yes i'm still on there. It's where i document most of my work. I did change my name on there though to better reflect where i'm going with things: _outlawmotorsports_
Thanks for the kind words.
Following you on IG now. My username there is the.bulletproof.garage.
Scott
Monza Harry
Windsor ON
Those are some nice updates you are sharing there! Your steel rack turned out pretty sweet the only future upgrade I see [aside from being bigger as all of us want] is to see if you can get some expanded wire screen bent into a shallow "C" for the span between the arms, for short length steel control [I see you did integrate a shelf that will be handy!] Easy 1 piece at a time upgrade, as time, money, and need arise. That horizontal/vertical mill will hog steel like crazy in my experience. The limiting factor I've experienced is the ability to hold the steel while squaring from the table (in horizontal position). I wish I had room for a small horizontal mill, not often used but very good at its best functions. The rest is pretty top shelf too! Please keep sharing for us mere mortals. Thanx Harry
