In an effort to consolidate and document the various small projects that run through the shop, I've decided to start this new thread. Any tool and equipment related content will be added to the existing thread in the tool forum.
To start this off, I will detail a project that was completed this past weekend. A set of header pipes needed to be widened out by 2-3/8". This was a fun job that utilized a handful of different machines in the shop. The first step was to remove the flange from the pipes. I have no photo of this, but picture a guy going at a brand new header with a sawzall. Here's the aftermath:
The next thing to do was straighten out the ends of the pipes. These are used on a square port head. This was half way through:
All the pipes set back to round:
It's now time to make the new extensions which will also serve as the transitions. This was accomplished by using a mandrel and 2.5 tons of pressure in the press. The end result was more consistent than the hand beat factory ends:
After the transitions were complete, it was time to make a new flange. Over to the mill for this one:
The transitions are a tight and snug fit. This will be critical for welding:
With the extensions snugly in place on the flange, it was time to get the pipes fitted. Most weren't far off the mark, but a few needed a trip or two to the disc grinder. Once satisfied, they are tacked firmly in place:
It's been soo long since I've done AN hard lines that I can't remember what tool I last used to flare them?
