mkbrower
To supply power to my shop, I want to install a disconnect panel at my house meter base and then run cable from the disconnect panel to a load center inside the garage. Do I need to run the grounds as if I am coming off the house main load center or run the grounds as if coming straight from the meter base.
If I run the ground as if I am coming off the house main load center, do I have to have ground rods at the shop connected to the shop load center as well as the ground coming from the meter base via the quick disconnect.
Any help will be appreciated!
Mark
Mark
