benwah
Hey all, just finished up a 660 square foot garage for a customer wanted to post some pictures and explain my process on how I do these types of floors.
First Step was to mask off the house man door from the garage and the windows, and other important items in the garage that I did not want concrete dust to get into.
After that I started the perimeter and body grind. Ground the body with 60/80 grit metal Bond diamonds. Next I routed out all cracks and joints with a four and a half inch hand grinder with a diamond blade on it.
After a good vacuum I filled all of the joints with sand and 100% solids epoxy joint filler and let it sit overnight. The next morning I came in and ran the grinder real quick over all joints and areas that I filled with the joint filler to make them flush with the slab.
For primer I used 3 gallons of clear 100% solids epoxy and thinned it 20% with solvent. Roughly 220 sq ft per gallon.
The next day I came in for the body coat. Ended up using 4.5 gallons of 100% solids epoxy with light grey pigment. Roughly 150 sq ft per gallon. Then I broadcast flake to rejection. I usually go closer to 100 sq ft/gallon but this slab was in excellent condition.
The next morning I came in and scraped all of my flake from east to west, then north to south. I then broomed it into a pile and reclaimed it. Then I gave the floor and excellent vacuum. Pictured is the scraper I like to use. It is heavy and does a great job.
For the top coat/grout coat I used 6 gallons of a two-component 100% solids Polyaspartic. Roughly 110 sq ft pet gallon @ 14 mils thickness. One coat.
Here are some pics of the process...
