Furring strips
S2R1000
So I need to pad the existing studs out a bit .
Existing are 2.5" , so I need another inch.
Is it a problem to use 1/2" drywall to gain the 1"?
Or is plywood necessary. Going to be hanging 1/2"
Sheetrock.
Thanks!
rlitman
Long Island
I've seen it done that way, and it can work if you use longer screws for the drywall on top.
But, are we talking about a small area?
S
S2R1000
Yeah that was the plan.
I assumed it'd be fine, but just wanted to double check. Thanks !
nadogail
Coronado, CA
You can temporarily attach the furring strips to the existing studs with construction adhesive, then fasten the drywall to the furred out studs with the longer Drywall Screws.
