I needed a crane, but didn't wanna build one til I have a bigger area to work on tractors, dump truck, 50' manlift, etc, so I bought one of the HF "1 ton" cranes - the stock one is NOT wide enough to get my Case backhoe between the uprights, (the stabilizers don't clear) so I bought some 6" x3.33" I beam, 12.5#/foot (1" taller and .35" wider than the HF one) - cut a piece of that 12' long to replace the stock I beam.
I also did NOT like the way the stock beam mounts to the legs, plus I wanted the crane WIDTH adjustable and less likely to "fold up like a cheap suit", so I "borrowed" one of Royce's ideas for braces that do NOT get in the way of full travel of the trolley; then I made mine not only adjustable, but completely removable.
For now the crane needs to move around on gravel, so 8" casters from Surplus Center replaced the 5" stock ones - exact same bolt pattern, tough mod :=)
Here's what I did; the result is a much stronger joint, and the braces are just far enough apart to clear both a 1 ton chain hoist AND a 1 ton electric hoist - BOTH will be on the beam when I'm done fabbing the "minimum height loss" trolley mount for the electric hoist... Steve
