I have a wood truss garage(20'x24') which I had them install enginered trusses for extra load and or storage in the middle. I was told as a whole, I could store 2000 lbs across the whole area. It is 4' wide and 24' long. I have installed 3/4" plywood to span across the area to make a floor.
I would like to put unistrut across 75% of the span and install a 800 lb electric hoist. I would like to install wheels so I can move it side to side. I would be using unistrut fasteners and hardware unless someone knows a better way.
Am I on the right track or is this an invitation to something bad happening?
At the most, I would probably only use 80% of the hoist capacity. I am using the ASYLUM thread and Shopnut's front loft hoist as insperation.
http://www.garagejournal.com/forum/showthread.php?p=1843980#post1843980
Thanks in advance for any help.
