Quick update -
The half mile event ended up being cancelled due to weather - and the trailer that I had rented to get up there ended up not working out. So thankfully I stayed home and saved myself 10 hours of driving.
I got a bunch of work done to the truck before that trip.
I added a trailer brake controller, picked up a hitch ball, replaced the U-joints in the driveshaft because it was vibrating really bad at 80mph, and I ended up replacing the Power Steering pump. All that work to get the truck done - and I ended up staying home, lol.
I also bought a new Spectre cone filter for the truck, and replaced the LLY turbo mouth piece inlet - with a newer LBZ unit. The LBZ outflows the factory LLY piece - and is supposed to lower EGT's.
I will be putting a downpipe back exhaust on the truck - I will be going with a Corsa 4" kit. I have Corsa on the SS and Vette - and love there product. Thankfully there truck kit prices are not too bad.
Vette - Nothing too crazy - resolved my oiling issues by adding in a PCV valve and a catch can into the PCV system. I also replaced the Holley valve covers with GM LS9 valve covers.
I ordered a Halltech intake shroud to go around the Edelbrock air filter. This should help lower IAT's and also seperate the intake from the hot engine bay temps.
SS - ordered some spaces to fit the stock SS wheels up front with the 6 piston V brakes. I'm taking that car on vacation next month and want to be able to use my full size SS spare wheel if I need to.
Garage - nothing too crazy - I finished trimming out 2 walls with the Racedeck. I borrowed a tablesaw - and man that cut through the tiles way quicker then a jig saw!
I also noticed that my China made hydraulic hose fittings on the Maxjax were dripping. Not a huge leak - but enough that I'd clean them up and the next day they'd be looking like they where going to drip again.
I checked the Maxjax thread - and found the part numbers for the "Non-Leak" fittings.
I found them online here:
www.hydraulics-etc.com.
PN:
FFH06 38NPT M
FFH06 38NPT F
Install went pretty quick - just make sure you disconnect the hose from the hydraulic ram in the posts.
So far - no leaks - and I raised and lowered the lift about 4x.
