Garage 2.0 - Building a Triple
bonecrrusher
Charlotte, NC
I've had a few people ask about my main toolbox - so I finally shot a review for it.
I've had the big Kobalt box form Lowes for a few years now - and I really haven't had any issues with it. This model has the little beer fridge in it - which they have updated with more tool storage.
I've been using this as my main box since my old house - and I filled it with tools.
All of the drawers are roller bearings - and open with no issue - even fully loaded.
To see my full review click below:
Thanks!
bonecrrusher
Charlotte, NC
I have been wanting to buy some LED strips for a long while now. I had watched a bunch of videos about them - and wanted to buy a set and see how they worked.
I ended up finding a set of RGB SMD 5050 LED strips for a great price. They are water proof - have 3 main colors - Red, Green, Blue - and have a remote control for them.
The LED strips came with the power supply box as well.
To begin the install - I mocked up the LED strips - and then cut them to the length that I needed.
After cutting all the strips - I trimmed the plastic coating that covered the copper circuits on the end.
The waterpoof coating has to be removed so that the connectors can slide over the LED strip - and then plastic caps can be snapped into place.
After getting the connectors and everything hooked up - I peeled the adhesive backing off of the LED strip and stuck it to the bottom of the cabinet. I put clear shipping tape every 6" or so over the LED strip to make sure it stays in place.
After the install - I hooked up the power and tested everything out - the 3rd bay setup worked fine with no issue.
The main bay strip however - the green color was not working at all. I swapped the white adapter control box from the third bay to the main bay - and the LED's lit up with no issue. I have contacted the seller - and I am getting a new control unit shipped to me. After that gets here - I will finish up the third bay install.
Parts Used:
5M 300 LED Strip Light 3528 5050 RGB SMD Flexible 44key Remote 12V Power
LED Strip Light Connector - 4 pin.
Pics:
For my full install/review - please watch my video below:
Follow me on Instagram: https://www.instagram.com/bonecrrusherss
Follow me on Twitter: https://twitter.com/bonecrrusherss
Like me on Facebook: https://www.facebook.com/bonecrrusherss
bonecrrusher
Charlotte, NC
I've had a few people ask about my MaxJax - and lifting my lowered Corvette on to it.
Since the Corvette is so low - I had to find a way to get the arms under the car.
I do this by driving up on a set of Race Ramps Scale Weight Ramps, lift the back of the car with a floor jack, then put another set of scale weight ramps under the rear.
This gives me enough room to get up and under the car - and raise it with the MaxJax lift.
Tools Used:
Race Ramp: RR-SCALE-2 http://amzn.to/2sKXIHT
For more information - please watch my video below:
bonecrrusher
Charlotte, NC
I have been looking at other brand tool boxes - and started to notice the latest trends that tool manufacturers are using in their new boxes. Then I noticed that Kobalt had come out with a new set of boxes that had internal charging for the upper box/tool storage area. So I did some research and decided I need to add a charging station to the top of my tool box.
Tools / Parts Used:
Kobalt Box #538543
Kobalt Power Strip: http://amzn.to/2C1fLlz
Desk Grommet: http://amzn.to/2BPTzIk
Hole Saw: http://amzn.to/2BAIdva
bonecrrusher
Charlotte, NC
More tools for the shop!
I needed to press out some bearings on the Corvette - and need a hydraulic press for it.
In the video below - I assemble and review the Harbor Freight 20 Ton Hydraulic Press.
Overall the install went pretty smoothly - I had to flip around the press I beam - and change the bolts on the bottom of the press since I put them in the wrong spot.
Hopefully these notes will help save you some time when you assemble your press.
Tools Used:
Harbor Freight #32879 20 Ton Press
Thanks everyone for all of your support!
ILLuSioNz X
Great thread, it was nice being able to read through a project like this from start to end.
bc.
St. Louis
Nice garage. Did you look at taking out that wall yet? Also, I know it has been a while, but what did you do with those brembos?
bj383ss
TX
Bonecrrusher haven't heard from you in awhile. What are you up to?
Bret
bonecrrusher
Charlotte, NC
BJ - honestly - been hard at work on my Youtube channel - been running that the last 2 years.
Currently - working on my upgrading the E-Force blower on my Vette.
Just installed a new clutch, ported the blower snout, 102MM TB, and a custom intake - that is the next build series for the car/channel.
As for the shop - just added more gear track and hung up some of my tools.
I still need to install a minisplit - cut a hole in the wall between the 2 bays - and other various projects.
