Elmo77166
I am going to build a 24x24 garage in the spring. I am using a kit from a local lumber yard. The walls are 2x4x10 studs on a 16 center. I want to install the walls on 3 course of block. The block is being laid on a concrete pad. My question is can I use 6 inch instead of 8 inch block? The block will have rebar stickers epoxied to the pad and the cells will be grouted full to the top. and threaded bolts in the block to bolt on the sill plate.
